2 minutes ago, PhoenixNDM said:
What do you mean?
That seemed pretty clear-cut to me. UBM is a horrible way to judge performance figures.
https://linustechtips.com/topic/1247883-need-help/#findComment-14029691
1 minute ago, PhoenixNDM said:
What do you mean?
Use Cinebench R15 or R20 and compare online (for the CPU). https://www.maxon.net/fr/produits/cinebench-r20-overview/
Use Unigine Heaven, Superposition or Valley and compare online too (for the GPU). https://benchmark.unigine.com/heaven
Use 3DMark (on Steam) and they compare it for you online both CPU and GPU score for gaming.
https://linustechtips.com/topic/1247883-need-help/#findComment-14029692
9 minutes ago, PhoenixNDM said:
I have a semi good game setup,but this setup gives me low fps on old games and medium fps on ne w games.I benchmarked my system and it gave me this:
I do not know why my setup is doing below expectations.Can someone help?
What speed is your memory running at?
(Task Manager > Performance > Memory > See speed in the bottom right. Probably somewhere in the 1066 - 1600Mhz range)
https://linustechtips.com/topic/1247883-need-help/#findComment-14029693
Just now, PhoenixNDM said:
1066
That will lower CPU performance quite  a bit and in my experience will also introduce stuttering in the games.
Do you know what set of memory you have bought?
Check the receipt/packaging of the memory if you have it.
Otherwise install CPU-Z, go to the SPD tab, click on the dropdown in the topleft and choose one of the slots where your memory is in, and please write down here what it says in "Part Number" (probably a list of letters/numbers/maybe a dash in there, depends on the manufacturer of the memory).
https://linustechtips.com/topic/1247883-need-help/#findComment-14029740
CMK16GX4M1D3000C16
https://linustechtips.com/topic/1247883-need-help/#findComment-14029750
CMK16GX4M1D3000C16
You have 3000Mhz memory running at 2133Mhz, that will lower performance.
You have to enable XMP/XAMP/DOCP in your motherboard BIOS to make the memory run at its full speed. If you don't know where to find that, please list the motherboard you're using so I can point you to where you can enable that.
Once you have done that, follow Meganter's advice on how to properly test your PC (Userbenchmark doesn't provide enough quality points of comparison IMO)
Once you have run these tests, you can give us the results, so we can judge if you are getting the proper performance from your PC
https://linustechtips.com/topic/1247883-need-help/#findComment-14029757
1 minute ago, Krishdude said:
I think that your PSU cannot supply enough juice to the components
Where do you see the PSU listed? What makes you think this?
Please don't try to confuse the OP with guesses of what you think is wrong; at least ask for the PSU model before making assumptions.
https://linustechtips.com/topic/1247883-need-help/#findComment-14029765
PRIME A320M-K
https://linustechtips.com/topic/1247883-need-help/#findComment-14029767
Just now, Krishdude said:
why?
he has low end cpu and low mid range gpu. hes memory should run at 3000mhz but it only runs at 2133mhz. low memory speed+ryzen=stutters.
psu has nothing to do with this
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1247883-need-help/#findComment-14029770
PRIME A320M-K
ok one of the worst mothebroards. still you have only 2200g so it should be fine. what psu do you have? go enable xmp in bios so your ram rusn at 3000mhz instead of 2133mhz
https://linustechtips.com/topic/1247883-need-help/#findComment-14029773
