Just now, mahyar said:
its a ok mobo adjust memory clocks and tell here
one of the worts motherboard. still VRMS should be enough for 2200g
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1247883-need-help/page/2/#findComment-14029774
2 minutes ago, PhoenixNDM said:
How do I open bios?
windows 10 settings- updating-recovery- advanced startup settings- troubleshooting- uefi
https://linustechtips.com/topic/1247883-need-help/page/2/#findComment-14029783
10 minutes ago, PhoenixNDM said:
How do I open bios?
Turn off your PC.
Now turn it on and start pressing the DELETE key on your keyboard constantly.
You should now go into the BIOS.
enable the feature show here:
Now press F10 (save and exit), don't touch the PC for a minute, it might turn off and on a couple times.
Now check your memory speed in the same way as before:
45 minutes ago, minibois said:
(Task Manager > Performance > Memory > See speed in the bottom right. Probably somewhere in the 1066 - 1600Mhz range)
You should see (around) 1500Mhz now.
Now run the earlier recommended benchmarks (I would just do Cinebench R20 and 3DMark TimeSpy within the demo on Steam) and report back the results of these benchmarks.
https://linustechtips.com/topic/1247883-need-help/page/2/#findComment-14029784
