3950x temps
Go to solution Solved by Lordofcheez,
1 minute ago, Mateyyy said:
Yeah, don't do that.
Use the Offset Mode, and do a -0.05V negative offset on the Vcore. You could go lower after that, but that's just to start.
First though, use the Auto voltage, run something like Cinebench R20, and note down your temperature, Vcore voltage and CB score. Then undervolt, and check those again. You don't want your performance score to drop (at least not too much), but you'll want to see those thermals go down.
okay heard that Ill try that later considering I dont want to spend another hour testing everything again.
Hi, I have had my 3950x for awhile now and I have always had a problem with the temps. When I leave everything at auto the max it gets is 85c. When I drop the voltages to 1.3v in the same tests (cine and blender) it reaches 100c. The case I am using it the nzxt h500i and the cooler is a noctua dh-d15 with only one fan. Im hoping someone could explain how I can get better temps. I have replaced the thermal and mounting it to the cpu twice now so im sure its not that.
https://linustechtips.com/topic/1246817-3950x-temps/
Take off the front panel and retest your temps. Odds are your case isn't allowing your system the airflow it needs to keep everything cool.
That second fan also does help a lot but given your case you probably cant fit it.
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021384
that's the normal operating temp of that cpu under that cooler, in that airflow restrictive case
undervolting, got my 3900x to 66c from 77c at stock, running 1.1v now
i kept my cores at around 3.95ghz at 1.1v, which is similar to stock all core boost clock at 1.25v
wattage dropped from 140W to 110W, temp from 77c to 66c, CB score about the same
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021385
10 hours ago, _DeXTeR_ said:
On what CPU fan
10 hours ago, Lordofcheez said:
noctua dh-d15
Hi,
Ambient temps? and you could try removing the side panel and check temps as said above, if that drops down the temps significantly then it's likely bad airflow in the case.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021424
What do you mean you "drop the voltage to 1.3V"? The stock all-core voltage should be lower than that.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021441
yes the side panel does drop it a lot should I just get a better case?
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021457
what are your temps exactly when the side panel is off?
Build Log:
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021460
okay ill try a 1.1 do you think I can at least have the ratio to 42?
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021464
2 minutes ago, Lordofcheez said:
meaning in the bios I have manually set the v core to 1.3 im using the asus bios btw
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021468
It drops about 15-20c when everything is stock and the side panel is off the max it gets is 68c at 3.9ghz
Oh yea so the airflow is pretty bad.
Build Log:
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021473
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021476
you cant take off the front panel on this case.
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021484
Oh I thought this was the glass front panel Elite version. My bad. Tofu's suggestion of the side panel as a test to alleviate any airflow bottleneck will also suffice.
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021507
No it is def airflow bottle necked I know that it was just weird that I was getting higher temps when putting it at a lower voltage. With the offset tho and not manually doing it seems to be working just fine.
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14021528
tough, i got to 4.0 with my best CCD, 4.2 is much harder to get to, probably need a super good die
edit: yea it's basically near impossible on 1.1v
https://linustechtips.com/topic/1246817-3950x-temps/#findComment-14022047
