Samba outside-network (yes i saw pin)
Go to solution Solved by Jarsky,
1 hour ago, IAmAFrenchFry said:
Looks like a few people say NextCloud
Yeah NextCloud or OwnCloud are fairly simple solutions to setup and are fairly secure with no known major vulnerabilities.
When I setup my NextCloud, took me about 30 minutes to install & configure.
and that SMB isn’t safe over WAN unless using a VPN
SMB should never be exposed to the internet for WAN. Especially SMB/CIFS 1.0 as it major security issues.
However, you haven’t given me a guide on how to do it with a VPN, so I don’t know how to take further action.
In a typical home setup, you only have a single network...so you create your SMB share internally as you would, and ensure that you can access it fine on your home network.
Then its just a case of installing a VPN server, and setting up a VPN client on your device you want to connect from. Theres no special SMB related configuration required.
Theres lots of how-to's on setting up VPN's, such as this one for OpenVPN Server on Raspberry Pi: https://www.pcmag.com/how-to/how-to-create-a-vpn-server-with-raspberry-pi
So, I have Samba installed on a Raspberry Pi with a USB Hard Drive for a NAS (as one does, of course), but i am confused about how I can remotely access it. I did read the pinned message, but it was a little confusing imo, and i’ve also seen things that say some things are more secure than others, slow speeds and latency could be introduced heavily, etc.
So what option do you guys think is the best combo of security, price (has to be less than cloud, preferably free obv), and just general overall happy-fun-time-i-ness. If you want me to switch to another file service instead of Samba, I would need a guide for how to set that up on RPi. Additionally, if you could provide a guide for how to do whatever option you would suggest for my situation, that would be helpful (and like one of the main reasons I am writing this).
Lastly, in case you select the port-forwarding option, I have attached an image of the port forwarding section on my router’s interface, so I would appreciate if you could tell me what to fill in those boxes.
Thanks!
You really don't want smb over wan, its a bad idea.
Either put this over a vpn, or use something that made for connections over wan, so a https based protocol, you can use something like nextcloud to make this easy, or something like scp.
Thanks!
3 minutes ago, Electronics Wizardy said:
You really don't want smb over wan, its a bad idea. Either put this over a vpn, or use something that made for connections over wan, so a https based protocol, you can use something like nextcloud to make this easy, or something like scp.
THIS. ^^^ I would strongly caution against exposing SAMBA/SMB over the internet due to security implications and inconvenience compared to using a more secure platform like NextCloud on your Raspberry Pi. There are quite a few guides out there if you search "Raspberry Pi NextCloud server" - I've linked the one that looks fairly straightforward below for you to get started.
https://pimylifeup.com/raspberry-pi-nextcloud-server/
Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | Koodo - 75GB Data + Data Rollover for $45/month
Laptop: Dell XPS 15 9560 (the real 15" MacBook Pro that Apple didn't make) Tablet: iPad Mini 5 | Lenovo IdeaPad Duet 10.1
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 | Panasonic TS20D Music: Spotify Premium (CIRCA '08)
Yup, you want to set up a VPN so you can become "internal" to your network before reaching it.
F@H
GPD Win 2
Thanks!
So I've actually just updated that post for the first time in 4? years. Don't make it available over the WAN. Depending on your gateway/firewall manufacturer, look at creating your own VPN solution.
@IAmAFrenchFry
why not Install Owncloud onto your RPi? to secure it, get a free SSL Cert from https://letsencrypt.org
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
Sorry I had school and couldn’t respond.
Looks like a few people say NextCloud, and that SMB isn’t safe over WAN unless using a VPN. However, you haven’t given me a guide on how to do it with a VPN, so I don’t know how to take further action.
Thank you @kirashi for providing a guide; I’ll look into it.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | EVGA GTX1070 FTW | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 14 x 20TB Seagate Exos X22 20TB | 500GB Aorus Gen4 NVMe | 2 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
Thanks! Would one of these options be better than the other (NextCloud or VPN)?
Theyre different solutions.
NextCloud is a web browser solution, think of it like a web version of Dropbox.
You create users, and you map folders to your users of what they can/cant access, and they can upload/download files, they can also preview/edit documents and watch/listen to media via the plugins directly in the browser.
VPN is a network solution. When your VPN is connected, its literally like you're connected to your network at home...e.g its just like you're on your home wifi. So you'd access things like you would at home, such as through File Explorer, play media through VLC, edit a word document through Word, etc....
Personally I use NextCloud for my solution as I might just want to share the odd document and create a shareable link to friends. Or occasionally access my media content from someone elses computer or a work computer, or a network that doesnt allow outgoing VPN connections.
So I decided to go with VPN option, however I notice in the guide that I still need to port forward the VPN port, but not an SMB port, which makes sense because typically when making VPNs accessing them is fun.
I’m assuming so, but just to be sure, still safe?
Yup, it's just a listen port. You need to forward the port, so that incoming connection requests for the VPN service get directed to your VPN server.
So it says the port is 1194. Would i put that in the internal and external port boxes and my raspi address in the internal ip box? and set it to udp?
Yeah, theres no reason to remap through non-standard port numbers with how efficient port scanning bots are these days.
So yeah UDP Port 1194 and everything as you've said, you got it 👊
Everything worked! Tysm!
