Best PSU for a new system
Wlayey
Hello,
I will be building a 3900X/RTX2080 based system soon, and I would like to choose a good PSU for my build:
Here are some ones that I found (in Hungary):
Bitfenix Whisper M 850W Gold BP-WG850UMAG-9FM 5 yrs 38250 HUF $128.4
Super Flower LEADEX III RGB 650W SF-650F14RG 5 yrs 39500 HUF $132.6
be quiet! Straight Power 11 650W Gold BN282 3-5 yrs depending on shop 42500 HUF $142.6
Seasonic Focus PX-650 Platinum   5-10 yrs depending on shop 44500 HUF $149.3
Corsair RM750x Gold CP-9020179-EU 5-10 yrs depending on shop 44990 HUF $151
Corsair RM850i Gold CP-9020083-NA 5-10 yrs depending on shop 45500 HUF $152.7
Corsair RM1000x Gold CP-9020094-EU 5-10 yrs depending on shop 51500 HUF $172.8
Out of these, which one(s) would be the best option? Any other recommendations?
Will the RM850i work (hence the NA tag at the end)?
To be honest, I am leaning towards the Seasonic (as I had a SS12G with NO issues for 6 years), or the be Quiet (it looks cool, I had one in the past which was silent af).
Requirements are basically silent operation, and long cables (Enthoo Pro is 535mm / 21.1in tall, so the EPS cable should be long enough).
Thanks a lot!
8 minutes ago, Wlayey said:
Hello,
Thanks a lot!
I've never heard of Bitfenix or Super Flower before, so I definitely wouldn't get those. To my knowledge, Corsair PSUs are usually good quality. I'd personally get one of the Corsair RM options depending on how much wattage you want.
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
11 minutes ago, Wlayey said:
Bitfenix Whisper
I would get this one, its A Teir rated on the PSU tier list.
3 minutes ago, RAM555789 said:
14 minutes ago, Wlayey said:
Bitfenix Whisper
Interesting. I'd never heard of the brand before (as I said in my post), but I guess it must be good then
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
Then you would be missing out on good PSUs. Super Flower is one of the manufacturers, like Seasonic. They have a wide variety of PSUs ranging from mediocre to high quality, but the Leadex III ARGB is also one of the best PSUs out there. Bitfenix gets most of their PSUs from CWT like Corsair and their Formula Gold and Whisper M PSUs are some of the best out there.
@Wlayey  Honestly, the Whisper M is a steal compared to the rest of them
MAIN PC:
CPU: Intel® Core™ i9-9900K Processor  Motherboard: Gigabyte Z390 Aorus Pro Wifi  CPU Cooler: Scythe Fuma 2  GPU: EVGA RTX 3080 FTW3 Ultra  RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red  Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
SECONDARY PC:
CPU: Intel® Core™ i3-9100F Processor  Motherboard: ASRock Z390 Phantom Gaming 4-CB  CPU Cooler: Arctic Alpine 12 CO  GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16
Case: CyberpowerPC Onyxia  PSU: ATNG ATA-B 800w 80 Plus Bronze  Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM    OS: Windows 10 Home
Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti
The Whisper M is a steal at that price. The only one worth it other than it is probably the RM850i, and that is if you want the digital monitoring and control.
850W is quite excessive though for just a 3900X and 2080 though.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
I would say the Corsair RMX 750 Or the RMI 850W if wanted the Digital interface.
The RMX and RMI will run quiet, more so than the Seasonic Focus.
Yes the RMI 850W will work fine, why wouldn't it?
Anything more than 850W would be unrealistic for the system even with future upgrades to the 3000 Series Nvidia cards.
Unless they start making 550W to 600W GPUs down the road, I suppose one never knows what's going to happen...
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
4 hours ago, Ankerson said:
550W to 600W GPUs
Thats a very scary thought, with the sheer amount of cooling you would need for something that insane.
I know, one would need a separate case just for the GPU cooler. LOL
