Help me to select AIO for my 3900X
15 minutes ago, pathikrit said:Thanks for the response, LF II 280 fits my budget good, just one question, hows the quality of the product since it will be running almost for days some times, also how it compares with聽kraken x63
You can check out GN's review of the LF II, where he tested the 280mm variant. The Kraken X63 doesn't seem to be present in the charts, but the 360mm X72 and 280mm X62 are,聽and the LF outperforms the 360mm聽by a couple degrees in the noise normalised test, despite the surface area deficit:
When testing with the fans running at full speed, the LF II 280mm is on par with the X62 and X72 cooling-wise, while being much quieter:
聽
Regarding quality, I haven't heard of any widespread issues with the Liquid Freezer II, but granted it hasn't been out for very long yet.聽
Here's a teardown of the whole unit, if you're interested:
