Thermaltake Smart bm1 600watts vs seasonic gc 550watts
Solved by Mateyyy,
2 minutes ago, Spiderman8 said:But for the thermaltake smart bm1 does it have a huge comparison? Or just a little
What do you mean, as in if the difference between the Smart and these other ones is large?
Yes, in fact one could argue that the Smart is pretty much garbage for any modern components. It's, at best, a very mediocre group regulated unit.
I'm not saying it'll blow up with a 1050Ti, but personally I wouldn't use it. If you have to go cheap, a be quiet! System Power 9 is still way better.
