Best aspect ratio for a modern panel for gamecube?
starry
I have a Gamecube, it looks like stretched garbage on my 16:9 panel, and even my 4:3 one. I have a dongle that lets me use HDMI, and many other dongles to adapt hdmi to whatever I want. Im wondering what kind of panel I should look for other than a CRT (they give me a headache) to play my Gamecube on. I dont like letterbox mode either, it feels lame. I just need the closest aspect ratio I can get, so that the stretching isnt so bad. Google hasnt been very helpful.
Daily Driver (Lenovo Y700 Laptop)
Manjaro Linux  ||||  Intel Core i7-6700HQ  ||||  16GB DDR4-2666    ||||   GeForce GTX 960m
250GB Samsung 970 Evo | 500GB Samung 840 Evo
Windows Gaming PC
Windows 10 Pro  |||   Intel Core i7-10700k  |||   32GB DDR4-3600  |||   GeForce GTX 1660 SUPER  |||   MSI z490 A-Pro  |||   EVGA Supernova G2 650w 80+ Gold
120GB SSD | 1TB WD Blue 7200RPM
Bedroom HTPC and Emulation Box
Manjaro Linux  ||||   Intel Xeon E3-1231v3  ||||   8GB DDR3-1333  |||  Radeon RX 460   |||  Asus B85M-G
120GB SSD
Living Room HTPC - Optiplex 790 SFF
Manjaro Linux  |||  Intel Core i5-2400  |||  8GB DDR3-1333  |||  Radeon HD 5450
120GB SSD
Smaller CRT's have less flicker, so I prefer those. Still though I'm looking at 4:3.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Fedora 38 x86_64
Secondary: AMD Ryzen 5 5600G, 16 GB 2667 MHz DDR4, Fedora 38 x86_64
Server: AMD Athlon PRO 3125GE, 32 GB 2667 MHz DDR4 ECC, TrueNAS Core 13.0-U5.1
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x, Windows 11 Home 22H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4, Windows 10 Pro 22H2 x86_64
Gamecube plays natively on 4:3 but has games that allow 16:9. So I think something is wrong with your display.
Gamecube is optimized for CRT 4:3 so it will looked garbage on modern lcd.
This is the same panel Ive used as my second monitor for years with no weird stretching issues, perhaps theres something wrong with my HDMI dongle
Windows Gaming PC
120GB SSD
120GB SSD
Oh interesting. Is there anything I can do about that? CRTs give me a really bad headache, Im extremely sensitive to light.
Windows Gaming PC
120GB SSD
120GB SSD
I fixed the issue by using a higher refresh rate crt for me when using my pc but other than that not really. The other step is emulation.
What refresh rate do you use? So I can get an idea of what numbers to look for.
I was just a kid last time I had a CRT so I have no idea.
Windows Gaming PC
120GB SSD
120GB SSD
I used a 1600*1200 crt at 85hz refresh rate went up the lower I put the resolution tho.
Good to know, thank you
Windows Gaming PC
120GB SSD
120GB SSD
The GameCube natively outputs at 720x480 at 60/59.94 (if you wanna split hairs) Hz. I believe most HDMI solutions for the GameCube that rely on the Digital AV Out allow you to force an output of 640x480, as nothing really goes past that on the system, so if it has settings that allow you to do that... do that.
Good information, thank you.
Windows Gaming PC
120GB SSD
120GB SSD
I'll add to that blurb with this: most games were designed to be displayed at 720x480 in a 640x480 frame. It's why render resolutions of something like 584x480 aren't uncommon. Essentially, the GameCube tends to display like this:
Which makes it a little annoying to make work on a 4:3 monitor, because unlike the Xbox, which stretches all the output to the full 720x480 frame and the PS2, which displays things in a 640x448 frame, the GameCube's odd choice of framing its output can make it really tedious to work with, at least concerning trying to display it on a 4:3 monitor.
I have a GameCube (early model with digital output connector, which I never had the cables for) and my computer monitor support composite (as well as component, HDMI, Display Port and DVI but that is not the point). It's fine. But my monitor support something your TV needs and that is 1:1 mode. Check your TV for this mode.. This mode will not stretch the aspect ratio.
Then the rest comes from how good the TV is at converting analog signal to digital.
GameCube supports 16:9 on select games only. Progressive scan is also on select games and require the rare component cables to use.
As a PAL Gamecube Owner I can say for certain the the 4:3 ratio was used in all the games. The Few games that have a 16:9 ratio started in a 4:3 ratio.. (In my personal Collection only two games I am aware had support, F-Zero GX and Star Fox Adventures.)
Another issue is which was still present during this era, was that some games ended having noticeable letter box effect on PAL systems (This was often a side effect of 60Hz NTSC conversion to 50Hz PAL). I'm personally not aware of GC game that this effect, but I've spotted it on several PS1 and PS2 games of the era.
Also as Digital Port GC owner, I'd use the Eon MK2.. and setting things to be at 4:3 best way to go.
