Troubleshooting Mixer and Audio Interface - Audio Noob Needs Help
Solved by The Flying Sloth,
Okay, here's your issue, you bought a very sensitive microphone and want it to be loud but not sensitive... You seeing the problem here?
If you don't want it picking up background noise your choices are pretty much as follows,
1, get a hardware compressor/limiter and use the mixer as a preamp
2, get a less sensitive mic like a dynamic mic
3, get a more directional mic like a supercardioid condenser (that's what I use)
If you're looking for broader info on mic types or recommendations the link in my signature may be of some use to you.
