Hi, im planning to change my stock cooler on my 1060 to a evo 212 for better thermals and i was wondering if i can use conductonaut liquid metal on it, it has 3 copper heat pipes but also have a little bit of aluminium, my question is, has anyone here used liquid metal on a evo 212?, the vram has no heat sink so i would have to address that to
https://linustechtips.com/topic/1216280-1060-cooler-mod-question/
I wouldn't recommend using liquid metal on a GPU. It's definitely overkill for a 1060.
You'd also have to figure out a custom mounting solution for the 212, almost no CPU cooler will fit on a GPU out of the box.
Before you get super far into this, what are your thermals like? There is a possibility that you could fix whatever issue you're having without the need for modding a different cooler onto your GPU.
You're planning on using a 212 Evo on a GTX 1060 GPU? Firstly liquid metal on a GPU is a no no. Second the 212 isn't made for GPUs so you would have to custom rig it to fit and work. The 1060 isn't really a card that needs anything more than the stock cooler, if you are having cooling issues I would suggest simply re-pasting card before trying to replace the whole cooler.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
What thermals are you getting currently, what model 1060 is it, how's the airflow inside your case and what are your ambient temperatures?
What you're planning sounds extremely overkill for a 1060 and most likely not worth the time and hassle.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Why mod ?
What's your temps ? And a cpu cooler will need some work
As for the liquid metal
It's over kill and I don't recommend it.
Phone: Pixel 3a (Purple-ish).
Build Log:
That GPU already has Kryonaut on it, but the "heatsink" that has is very weak, thermals jump from 50 to almost 100 very quickly, and the noise is really bad, i have my PC usder my bed, and i want it to be quiet AF because i have a baby and the noise wakes her up, i already have watercooling on the CPU so no problems with that part
Carpet too?
Whats your airflow like?
BTW if I had a spare GPU and a spare 212 Id try it too, just no liquid metal
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
2 minutes ago, Papichulo said:
PC usder my bed
No fresh airflow? This is your problem.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
high 90's to low 100's, im trying to learn blender in my spare time, i have a several evo 212 and i think i have seen a lot of lunis videos doing weird stuff to think i can do this without a problem, i was thinking about the liquid metal because i have some laying around, so i would not have to purchase anything
The PC is probably being choked for air under a bed, hence the random spikes and loud fan noise, it's trying to cool itself the best it can while under a bed, same thing happens when you enclose a PC in a cupboard with no airflow running through it. If you really have to replace the cooler and want it as quiet as possible maybe look into the NZXT AIO GPU mounts. Maybe get a 120mm AIO and the mount, or possibly buy an aftermarket air cooler specifically made for the GPU you have. And definitely remove it from under your bed...
1 minute ago, Papichulo said:
tiles, airflow is very good, 4 fans blow air in to the case, and 1 exhaust fan
Not case airflow
The pc has not fresh air to breathe
Try putting it on the desk or something
Build Log:
im not in my home right now, but i can assure you that it has a good airflow, at night (when i use my PC) we have the AC on so ambient temps ar like 22c-23c
1 minute ago, TofuHaroto said:
Not case airflow
well, thats that, im going to place it somewhere else in the room, i have a 7mts HDMI cable so that its not hard to do, but the problem is the wife
It's not about ambient temps, it's about it being under a bed. It's a cramped space and depending on your bed setup it will have impeded airflow, it's even worse if it's on carpet under the bed, the amount of dust build up there is under beds is no joke. The computer will not be getting adequate airflow unless it is positioned in an open area and on a flat hard surface, not on carpet. Impeded airflow causes loud fan noise and temperature fluctuations which you are suffering from. Ambient temps don't mean jack when the computer is in enclosed space where all of the heat it puts out is just going to sit with it and stay in the same space and it can't draw fresh air into it.
Did you do the repaste yourself, or did someone else do it? Is the cooler tightened down enough back onto the die?
Also, what case is it? You said it's got 4 intakes, 1 exhaust and it's under a bed, but four fans could all spin at max speed and do nothing if the case cant pull air form where it needs to.
Under your bed is basically a thermal blanket.  Its probably even heating up the underside of the bed meaning the ambient temp, under the bed, is much higher.
You are recycling (likely) hot air.
I would TRY it outside the bed, to rule out this being the issue or not.
Secondary I would try to place it where the exhaust portion of the case is feeding cool air in (I.E. at edge of under the bed) and F what the exhaust is doing as long as its not getting drawn back in the case.
i did it myself, im not new to PC stuff, in fact the Lenovo T440p which im using right now to write this has liquid metal, i know the risk but also know how to handle them, im asking if its safe because i cant find a video with someone using liquid metal on a 212, i was planing to do that because i have all the stuff laying around in the house, and i want to do something because the quarantine, 2 fan are pulling fresh air from the end of the bed ( i dont know how to put it since english its not my first language), the fans of the rad do pull air from under the bed, but since its overkill for a 1600x the fans dont go to fast, its just the GPU that makes the noise, and since im going to use it to render stuff, i want it to be as cool as possible so we can chill together
the fans at the front of the case are at the edge of the bed, the only fans that are recycling hot air would be the ones at the rad
