CPU cooler for Ryzen 2600
Siruspc
hello guys i recently open post because i coudn't open my pc because i undervolt it too much(i guess) i did that because my CPU is overheating. Right now im doing unpacking a file and it's gonna take more than hour and it's 8 minutes in already 82 degrees and dropped to 3.5ghz(everything auto in bios) i pretty much see this result in every game too i have stock cooler and ryzen 2600 on b450 tomahawk max mobo can you guys tell me good price to performance coolers can handle 4 ghz with good temps
Thermalright True Spirit 140 Power
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti and RTX 6800 | Corshair psu
what country
Primary PC:
i live in Turkey
this cooler is not available in my country
What case and ram are you using? Budget?
Case -Corsair Spec Delta RGB
Budget- is kind a hard to give amount from other currency but i would prefer max 40-50 dolars
On 5/28/2020 at 4:36 PM, rqb2001 said:
looks sick but sadly not available in my country
what you guys think about Hyper 212 Black Edition
Usually its expensive. Arctic Freezer 34 and Deepcool gammaxx 400 are great in about 23-30€ range.
it's almost same price with Arctic Freezer but i heard people has issues with Arctic Freezer being not compatible with tomahawk max boards otherwise i was going to buy it
What makes the freezer 34 incompatible with Tomahawk max?
Cheapest I'd go is Snowman M-T6
About ~20€ and does pretty good.
I edit my posts more often than not
size after buying if doesn't fit you need to ask them to sent different bracket for tomahawk motherboards that's what they say and i don't know how long does it gonna take so i don't wanna bother with that.
No need to convert currency when that's not what you're using -- so ~300tl?
The Hyper 212 BE is decent.
If cheaper, some similar alternatives include:
Hans: https://www.sinerji.gen.tr/reeven-hans-rc-1205-120mm-intel-amd-uyumlu-hava-sogutucu-p-34992#nav-technical-specs
CNPS10X Optima II: https://www.sinerji.gen.tr/zalman-cnps10x-optimaii-rgb-siyah-120mm-intel-amd-uyumlu-hava-sogutucu-p-32245
Gammaxx 400: https://www.incehesap.com/deep-cool-gammaxx-400-intel-amd-120x120x25mm-fan-mavi-led-islemci-sogutucusu-fiyati-36119/
For the Hans, I'd recommend checking in with the seller if it already comes with an AM4 upgrade kit.
