RTX 2080 air cooling is like a turbine.
Sargon
Only when I started testing RTX games, did I hear the full power of my RTX 2080 fans.
I am almost certain it's the fans of the RTX GPU but I could be wrong.
Is it suppose to be so loud?
It does monotone burst with the fans.
Does loud noise for 1 or 2 seconds, then no noise for 1 or 2 seconds.
So it's hard to hear what Lara is saying when playing like that.
Is this normal?
Is there a way to make things cooler? Like even turning on the AC could help?
The 2080 is a loud card but you can set a fan curve on msi after burner
Phone: Pixel 3a (Purple-ish).
Build Log:
stock coolers aren't enough to tame these gpus you really need a big 3 slot 3 gpu fan config to get them under control on air. 240mm of rad space will also do it
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
I don't understand.
Can I replace the fans on the GPU?
Where do I put the radiator? Or if I can replace it?
3 minutes ago, Sargon said:
I don't understand.
you'd need a with a different cooler not just fans
a radiator would mean water cooling it or using an AIO
Try setting a custom fan curve with Afterburner or E-Leet, smoothing it out will at least make it less noticeable.
The stock fans are typically why you avoid Founders cards and go for twin/triple fan cooler designers. Founders cards are more something you get if you're doing a custom water loop.
If you want to water cool the card there are options like
Kraken G12 Cooling Mount with a Kraken AIO cooler: https://www.nzxt.com/product-overview/kraken-g12
EVGA Hybrid cooler: https://www.evga.com/products/productlist.aspx?type=18&family=Cooling&chipset=GPU+HYBRID+Cooler
There are some aftermarket heatsink/aircoolers as well
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | EVGA GTX1070 FTW | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO | 12 x 8TB HGST Ultrastar He10 (WD Whitelabel) | 500GB Aorus Gen4 NVMe | 2 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
Check what i said above 😜
Build Log:
I think I have 3 fans, though the card is upside down it's hard to see.
I have a Gigabyte card.
Yes, I have Windforce 8G, it has 3 fans.
Is this normal?
it is loud. but you reallllly shouldnt hear it THAT much, unless you dont use headphones?
stuff is cool. stuff that has fancy lighting is cooler. stuff that has fancy lighting and works is the coolest.
i game so i know a bit abt gaming tech, not much abt professional tech.
writing this as i finish a 3 hour D2 sesh so excuse anything wrong.
