Can I OC a hard drive? :D
Solved by Vishera,
Just now, SSD Sean said:No, you have to buy a faster product / go SSD
OP can also buy a 7200 RPM drive,
There is a significant difference in performance between 5200 RPM and 7200 RPM.
But a SSD is the ideal option.
Just now, Nena360 said:Its a dedicated STEAM drive how ever Steam can install games in multiple drives? Without issues?
I think that a 250GB or 512GB SSD is the sweet spot if you want it just for one or two games.
I install STEAM games to different drives without issues.
