Confusing 6+2 8 pin connectors from PSU
The 2 pin that is literally beside the 6 pin...
They go together...
You literally can't make it reach any other way...
That cable has two seaprate 6+2 pins on it, that's why the wires go from one to the other.
It doesn't matter which one you use.
You can use both at the same time if your GPU has two 8 pins or 8+6 pin.
Featured Topics
Anonymous1234 ·
Posted in Troubleshooting1 -
CasoF13 ·
Posted in Storage Devices1 -
hanouzz ·
Posted in Power Supplies8 -
Hellowpplz ·
Posted in Troubleshooting3 -
D. Sheperd ·
CGarza ·
Posted in Servers, NAS, and Home Lab3 -
MyLittleFella ·
Posted in Audio2 -
Renton577 ·
Posted in Laptops and Pre-Built Systems1
play_circle_filled
Latest From Linus Tech Tips:
iPhones Are Undeleting Nudes?? - WAN Show May 17, 2024
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
