NZXT H500 too Hot should I swap cases?
Naturr
System:
ASUS ROG Maximus XI Hero
Corsair Vengeance LPX 32GB DDR4 DRAM 3200MHz C16 Memory Kit, Red
Samsung 970 EVO Plus Series - 500GB PCIe NVMe - M.2
2080 Super
NZXT H500 ATX Computer Case, CA-H500B-W1
EVGA SuperNOVA 750 G3
15 minutes into a game like Warzone and my system BSOD's.  GamerNexus seems to say that this case with 2 fans is the best cooling option.  I don't know if I should replace the stock fans or swap it out for a Coolermaster H500M or Meshify C?   Budget is up to $400 and ideally I want it maintenance free and quiet.  I will do CLC if that is the best route but I would love advice such as "Get an Meshify C and add two fans two XYZ fanst to the front".   Thanks for the help all.
I doubt that a BSOD is caused by overheating hardware, unless it's a overclocked CPU not having high enough voltage. I would recommend to look into HWinfo while gaming to see if thermals are actually the issue. You could snap a picture of your BSOD, there usually is a code saying what is the issue with the system.
Did you actually check that your system is overheating? Would be unwise to just make an assumption.
I have the same case with an i5-9600K and RTX 2070 SUPER, temps never exceed 60C on my GPU, 70c on my CPU (both overclocked). The case has great thermals in my experience.
You still have to go in and clean dust out, this is  the same thing with all pcs
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
