Do USB 3.1 Gen1 Headers work with 3.2 type-A USB ports?
Solved by minibois,
2 minutes ago, Dan Flame said:Yes! Im trying to connect my case's front USB to my Motherboard, And im planning on getting the NZXT H500 ATX Mid Tower Case
and MSI B360 Gaming Plus Motherboard
Do you mean the H500 or H510?
The H500 only has USB 3.2 Gen 1 (also known as USB 3.1 Gen 1 or simple USB 3.0).
Your board has the header here:
I asked if you're gonna usethe H500 or H510, because the H510's USB Type C requires a different header:
H500: only needs the blue/larger one
H510: needs both. Your board only has a single blue/larger one.
TL;DR: if you're gonna use the H500 case (not H510), your board has the right connector.
