Case for mid-high tier build
Solved by ShinRamen,
1 hour ago, Manjit73 said:
This case has pretty bad airflow, front intake is obstructed by a ton of plastic. The advertised RGB does not work as pictured - you'll have to pick one color, no rainbow effects or anything if that's what you are after. (Unless they recently fixed that, which I highly doubt).
OP, you'll be far better off with one of the cases you mentioned. I'd recommend the Meshify C, it's a superb case. Corsair iCue 220T Airflow and Corsair 275R Airflow are two I'd like to mention as well.
