Thoughts on my 1440p 144hz mid-highend Build
This will be my first gaming build so I am very open to suggestion. As said in the title, I am planning a 1440p 144hz mid-high range build hopefully under 3000$ Canadian rupee (~2133.76USD). This budget including a decent monitor. Please see my specs below and look out for some further questions I put after:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($270.00)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($40.00)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($170.00)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory  ($106.99 @ Newegg Canada)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  ($170.00)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($75.00)
Video Card: Asus GeForce RTX 2070 SUPER 8 GB STRIX GAMING Advanced Video Card  ($850.00)
Case: Rosewill CHALLENGER ATX Mid Tower Case  ($64.99 @ Newegg Canada)
Power Supply: EVGA BQ 600 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($84.99 @ Canada Computers)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCIe x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($55.99 @ PC-Canada)
Monitor: ViewSonic VX2758-2KP-MHD 27.0" 2560x1440 144 Hz Monitor  ($450.00)
Total: $2337.96
Total w/Tax: ~$2,640.00
Generated by 2020-04-27 13:23 EDT-0400
As you can see I chose the R5 3600 paired with a Cooler Master heat sink. From what I have seen this is a great value I'd love to hear your thoughts. Should I spend more and opt for the 3700x and ditch the heatsink? This will be a gaming only rig with some very minimal software development so I didn't see the need for an 8c cpu for the some time.
Furthermore, I would like a 2070 super but am open to discussion here within nVidia for now(I.e. Would the 2060 be better value? How would it far with 1440p 144hz? Etc). More specifically, I wanted to ask about my decision to go with the ROG Strix 2070 super. Is this a good desicion? I know it is rated high in the tier list but why not save and get the EVGA 2070 SUPER BLACK GAMING for over 100CAD less and focus on good heat management in the case?
Thank you for any constructive response you give, it is very appreciated!
3 minutes ago, TrueTaylor said:
I would recommend swapping this out for a DeepCool Gammaxx 400 LED which is $13.01 cheaper while giving better cooling performance.
Link to DeepCool Gammaxx 400 LED:        https://www.amazon.com/DEEPCOOL-GAMMAXX-400-Blue-Compatible/dp/B00JQ2YDCY/ref=sr_1_2crid=HXG5G8D90HP9&dchild=1&keywords=deepcool%2Bgammaxx%2B400&qid=1588009109&sprefix=deepcool%2Bgammax%2Caps%2C552&sr=8-2&th=1
Review DeepCool Gammaxx 400 White
Hope this information post was helpful  ?,
        @Boomwebsearch
The 2070 super is the perfect card for 1440p 144hz gaming. I would say upgrade your ram to 3600mhz, upgrade the pay to an 80plus gold unit, swapping the motherboard to the MSI one with built in WiFi. Also you can save money by going with the gigabyte wind force with three fans. I do recommend 3 fans for the 2070 supers or at least 2.5 slot cards.
Good God do not pay that much for that motherboard. Way more than it's worth, you can get X570 boards for pretty much the same price.
For a little more you can get this:
https://ca.pcpartpicker.com/product/dmGnTW/asus-tuf-gaming-x570-plus-wi-fi-atx-am4-motherboard-tuf-gaming-x570-plus-wi-fi
You can also get a Crucial P1 1TB for substantially less than that. SSD is a rip off.
The cooler is trash. There are many, many better options out there.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Welcome to the forum!
28 minutes ago, TrueTaylor said:
-Snip-
I would change a lot in this build.
I recommend:
Just as good of a cooler for a lot less.
Motherboard with WiFi.
Better value NVME drive.
I personally cannot recommend the 2070S, for $850cad.... I bought by 1080Ti new for less than that, and with Nvidis releasing new cards this year I would be gutted spending $850 on a 2070S. The Rx 5700XT is nearly identical in gaming performance for a LOT less.
Better airflow case = better thermals = better performance.
Much better quality PSU.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
1 minute ago, Sorenson said:
I agree with most of what you said, I just wouldn’t cheap out that much on the case or cpu cooler. The 2070S looks a bit overpriced in CA right now.
Cheaper case but in terms of airflow it is superior to the H510, and it still has a TG panel.
Same goes for the air cooler, paying more money for pretty well aesthetics only, the R5 3600 runs pretty cool.
Nothing wrong with those choices, just won't yield any performance return for the money spent.
My Builds:
MEGA Desk Build
The H500 has good airflow as long as you set it up with the default fan configuration and has more cooler compatibility support if he upgrades in the future. Check out gamer's nexus review or Greg Salazar's review if you don't believe me. It is 80$ more than yours, but part of that comes from the better ram since he wants to do 144fps. Ryzen automatically overclocks when you lower the temperature so a better cooler will give higher FPS (probably only marginal differences though).
Not sure I understand the part picker list...
You lowered the build cost by choosing better parts, really good, but didn't really do anything with the extra money?  I know he said he was stretching budget and it was $2k, but if you can stretch, worth showing why it is worthwhile.
Better CPU and better MB still comes out better than original build price.
However, this doesn't really improve gaming, at 1440p.
So I created a second list which improves on gaming experience.
This second list improves gaming experience, buy upping the GPU, but is very similar to earlier budget, $40 dollars more.
I did take you down to 500gb NVMe, but for now that is sufficient to gain the improvements in performance.  You can buy another one in 6 months.
