Posted April 27, 2020 So I've only started very briefly educating myself about types of microphones and their characteristics, so please be gentle. I am going to put forward a scenario that is very far from "an ideal situation" in terms of audio quality, but for the more well-versed, what would you do if these were the restrictions imposed: 1. Wanting to record audio while at the same time, not have the microphone in the video shot (i.e. microphone cannot be close to the mouth) 2. Too lazy, unable to use a lavalier microphone 3. Potential typing and clicky noises from the talent Because of not being able to eat the microphone, I think maybe a condenser or a shotgun microphone may be desirable in this circumstance. I wonder in terms of noise rejection perhaps shotgun microphone may be more desirable over the condenser microphone at a distance since that may pick up more noise? - Shotgun microphone at a distance - Condenser microphone at a distance - Dynamic microphone at a distance Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 27, 2020 Generally the gold standard for recording at a longer distance is a shotgun mic. Overhead mounting would be a bad idea in this case, since you want to avoid clicking and typing noises, which would be coming from the same direction as the mouth of the speaker if sitting at a desk in that position. Not to mention overhead mounting is a massive pain. My suggestion would be a shotgun mic either attached to or just pointed in the same direction as the camera. That will give excellent sound quality while also reducing the pickup of the keyboard and mouse. ¯\_(ツ)_/¯ Desktop: Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 | Fractal Design Meshify C | Windows 10 Pro Laptop: HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 27, 2020 Author 2 minutes ago, BobVonBob said: If using a lav was an option, would this be preferable (in your opinion) over the shotgun? Since I understand most lav's are omnidirectional, would the keyboard/mice clack be too big of a concern and so you would still opt for a shotgun? Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 27, 2020 Shotgun mics are the best at pickup up directional audio, but booming overhead in your case will definitely pick up your keyboard clacks. I'd say the safest way is to point the shotgun directly at you from below, this will be less likely to pick up keyboard noises, but may still show up in the shot. so the best option I can think of for you will be to put it up where the webcam goes. Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset) /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry /// External Drives: 500GB Samsung T5 SSD (Working Drive) Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver) /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV, Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 27, 2020 2 minutes ago, For Science! said: If using a lav was an option, would this be preferable (in your opinion) over the shotgun? Since I understand most lav's are omnidirectional, would the keyboard/mice clack be too big of a concern and so you would still opt for a shotgun? Honestly I'd go with a shotgun mic any day. With a high quality shotgun mic you'll get pretty comparable sound quality to a good lav without the hassle of needing to use a lav. ¯\_(ツ)_/¯ Desktop: Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 | Fractal Design Meshify C | Windows 10 Pro Laptop: HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 27, 2020 A shotgun mic will certainly pick up keyboard noises and a lav may ignore most of them, honestly it sounds as though you want a headset mic (not the gaming headset kind, the stage microphone kind) as they will have a much better chance of ignoring keyboard noise than an omni lav or shotgun mic. If we weren't in lockdown I'd suggest getting one of each and trying it out in the scenario you want to see which is best and returning the surplus two. Sloth Sloth's the name, audio gear is the game I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus. Click here for my Microphone and Interface guide, tips and recommendations For advice I rely on The Brains Trust : @rice guru- Headphones, Earphones and personal audio for any budget @Derkoli- High end specialist and allround knowledgeable bloke Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 28, 2020 20 hours ago, The Flying Sloth said: A shotgun mic will certainly pick up keyboard noises and a lav may ignore most of them, honestly it sounds as though you want a headset mic (not the gaming headset kind, the stage microphone kind) as they will have a much better chance of ignoring keyboard noise than an omni lav or shotgun mic. If we weren't in lockdown I'd suggest getting one of each and trying it out in the scenario you want to see which is best and returning the surplus two. Sloth I'd second a stage headset mic - many of them are skin-coloured and very slim, and they aren't that noticeable. Take the Countryman E6, for example: https://countryman.com/product/e6-earset/ @For Science! is there any particular reason why the mic can't be in the shot? For Sale: Meraki Bundle iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 4, 2020 Author On 4/28/2020 at 8:33 PM, dalekphalm said: @For Science! is there any particular reason why the mic can't be in the shot? It's all hypothetical, but lets say aesthetics. If I were to add a little bit more, although it's going to sound stupid. "To look and sound professional during a teleconference session, but not look like you've put too much effort into making it look and sound good". So anything that suggests "this is not using a laptop microphone" (apart from the quality) is non-desirable. Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 4, 2020 On 4/27/2020 at 11:33 AM, For Science! said: Because of not being able to eat the microphone, I think maybe a condenser or a shotgun microphone may be desirable in this circumstance. I wonder in terms of noise rejection perhaps shotgun microphone may be more desirable over the condenser microphone at a distance since that may pick up more noise? It's a common mistake to believe that a microphone's type (eg: condenser vs dynamic) will have a direct affect on what it can and can't pick up. There are some small amounts of truth to that, but generally, it has more do with the mic's polar (pickup) pattern. I think a perfect demonstration is the fun that both Jayz2cents and Linus went through with their home streaming setups. Jay used a dynamic, and Linus a condenser. In fact, the mic Linus used is one of the best studio condensers available today: the Rode Broadcaster. What folks believe is something along the lines of: "Dynamics are good for noisy environments because they reject indirect sound better. Condensers are better for quiet studio settings." That's not really true. The Broadcaster, for instance, is an end-address mic with a tight polar pattern, and that's what matters. I can snap my fingers underneath the Broadcaster while I'm using it, and it barely picks that up. If at all. And remember: that's a condenser mic. Also, for the sake of being pedantic: shotguns are either condensers or dynamics (usually the former). I think what you meant, instead, was a desktop cardiod mic versus a shotgun. Ultimately your self-imposed restrictions are going to make this very difficult. Shotguns are perfect off-cam mics, but position is going to have a YOOGE impact on what it picks up and doesn't. Behind your display and aimed at your forehead might work since the keyboard will be a good bit off-axis (if that's what you're worried about). Editing Rig: Mac Pro 7,1 System Specs: 3.2GHz 16-core Xeon | 96GB ECC DDR4 | AMD Radeon Pro W6800X Duo | Lots of SSD and NVMe storage | Audio: Universal Audio Apollo Thunderbolt-3 Interface | Displays: 3 x LG 32UL950-W displays | Gaming Rig: PC System Specs: Asus ROG Crosshair X670E Extreme | AMD 7800X3D | 64GB G.Skill Trident Z5 NEO 6000MHz RAM | NVidia 4090 FE card (OC'd) | Corsair AX1500i power supply | CaseLabs Magnum THW10 case (RIP CaseLabs ) | Audio: Sound Blaster AE-9 card | Mackie DL32R Mixer | Sennheiser HDV820 amp | Sennheiser HD820 phones | Rode Broadcaster mic | Display: Asus PG32UQX 4K/144Hz display | BenQ EW3280U display Cooling: 2 x EK 140 Revo D5 Pump/Res | EK Quantum Magnitude CPU block | EK 4090FE waterblock | AlphaCool 480mm x 60mm rad | AlphaCool 560mm x 60mm rad | 13 x Noctua 120mm fans | 8 x Noctua 140mm fans | 2 x Aquaero 6XT fan controllers | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 7, 2020 On 5/4/2020 at 7:41 AM, For Science! said: It's all hypothetical, but lets say aesthetics. If I were to add a little bit more, although it's going to sound stupid. "To look and sound professional during a teleconference session, but not look like you've put too much effort into making it look and sound good". So anything that suggests "this is not using a laptop microphone" (apart from the quality) is non-desirable. Fair enough - I would say, who cares about that, because that's dumb. But if, say, because of management, they forbid you from showing a mic in-frame, the best thing to do would be to use a Boom or a stand (articulating arm, for example), to bring the mic as close as possible to the speaker while being just outside of the frame. In terms of mic type, as said below by @jasonvp, if it's a single person talking, you want a directional mic with a tight polar pattern that will only pick up sound from a specific direction, and then you do your best to get that mic as close as possible, while also minimizing or eliminating any potential sounds within that pickup zone. On 5/4/2020 at 10:25 AM, jasonvp said: It's a common mistake to believe that a microphone's type (eg: condenser vs dynamic) will have a direct affect on what it can and can't pick up. There are some small amounts of truth to that, but generally, it has more do with the mic's polar (pickup) pattern. I think a perfect demonstration is the fun that both Jayz2cents and Linus went through with their home streaming setups. Jay used a dynamic, and Linus a condenser. In fact, the mic Linus used is one of the best studio condensers available today: the Rode Broadcaster. What folks believe is something along the lines of: "Dynamics are good for noisy environments because they reject indirect sound better. Condensers are better for quiet studio settings." That's not really true. The Broadcaster, for instance, is an end-address mic with a tight polar pattern, and that's what matters. I can snap my fingers underneath the Broadcaster while I'm using it, and it barely picks that up. If at all. And remember: that's a condenser mic. Also, for the sake of being pedantic: shotguns are either condensers or dynamics (usually the former). I think what you meant, instead, was a desktop cardiod mic versus a shotgun. Ultimately your self-imposed restrictions are going to make this very difficult. Shotguns are perfect off-cam mics, but position is going to have a YOOGE impact on what it picks up and doesn't. Behind your display and aimed at your forehead might work since the keyboard will be a good bit off-axis (if that's what you're worried about). Excellent points here - the pattern that the mic picks up is by far the most important factor. There are mics with multiple patterns - such as the Blue Snowball and Blue Yeti - I imagine there are some XLR ones too. For Sale: Meraki Bundle iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 7, 2020 Author 7 minutes ago, dalekphalm said: Fair enough - I would say, who cares about that, because that's dumb. So after doing one big circle, do you have any recommendations for shot gun microphones (which I use in the sense of a dynamic microphone with a tight cardioid polar pattern). Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 7, 2020 On 5/5/2020 at 12:25 AM, jasonvp said: In fact, the mic Linus used is one of the best studio condensers available today: the Rode Broadcaster. Yeah, no, very no. Not even close to being a high end or studio grade microphone, has no bottom end and is crazy bright, the brightness might be excusable if it had the mid warmth of a traditional edge-terminated microphone but it just doesn't. For that price a 3U Audio Warbler or any Advanced Audio mic is a much better option. You are correct that polar pattern matters, that is why I recommend the Behringer C2 so often, supercardioid pencil mic that won't get in the way but it is still far more sensitive than any of my dynamic mics, especially on-axis. @For Science! If you don't want background noise you'll want to be looking at a stage headset mic or lav mic, used correctly either can be almost invisible and they will ignore far more background noise than any shotgun mic I've ever used. Sloth Sloth's the name, audio gear is the game I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus. Click here for my Microphone and Interface guide, tips and recommendations For advice I rely on The Brains Trust : @rice guru- Headphones, Earphones and personal audio for any budget @Derkoli- High end specialist and allround knowledgeable bloke Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 7, 2020 10 minutes ago, The Flying Sloth said: Not even close to being a high end or studio grade microphone, has no bottom end and is crazy bright, the brightness might be excusable if it had the mid warmth of a traditional edge-terminated microphone but it just doesn't. For that price a 3U Audio Warbler or any Advanced Audio mic is a much better option. This is a "Ford vs Chevy", "Coke vs Pepsi", or "Mac vs PC" thing. You clearly don't like Rode. I disagree with you, and yes, they are "high end". They're not "thousands of dollars" high end, but high end enough for this discussion. Their low end is perfectly acceptable if you know what you're doing. And you know what you're doing, right? Editing Rig: Mac Pro 7,1 System Specs: 3.2GHz 16-core Xeon | 96GB ECC DDR4 | AMD Radeon Pro W6800X Duo | Lots of SSD and NVMe storage | Audio: Universal Audio Apollo Thunderbolt-3 Interface | Displays: 3 x LG 32UL950-W displays | Gaming Rig: PC System Specs: Asus ROG Crosshair X670E Extreme | AMD 7800X3D | 64GB G.Skill Trident Z5 NEO 6000MHz RAM | NVidia 4090 FE card (OC'd) | Corsair AX1500i power supply | CaseLabs Magnum THW10 case (RIP CaseLabs ) | Audio: Sound Blaster AE-9 card | Mackie DL32R Mixer | Sennheiser HDV820 amp | Sennheiser HD820 phones | Rode Broadcaster mic | Display: Asus PG32UQX 4K/144Hz display | BenQ EW3280U display Cooling: 2 x EK 140 Revo D5 Pump/Res | EK Quantum Magnitude CPU block | EK 4090FE waterblock | AlphaCool 480mm x 60mm rad | AlphaCool 560mm x 60mm rad | 13 x Noctua 120mm fans | 8 x Noctua 140mm fans | 2 x Aquaero 6XT fan controllers | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 7, 2020 38 minutes ago, jasonvp said: This is a "Ford vs Chevy", "Coke vs Pepsi", or "Mac vs PC" thing. You clearly don't like Rode. Yeah, no, again, I love some Rode mics, the NT1 and NT2 certainly aren't bad for the money and the Classic is one of my all-time favourite microphones, the Broadcaster just isn't one of them, it comes much closer to the NT1-A in terms of crazy brightness that makes it unusable on most sources (works pretty good on dark acoustic guitars I will admit) without copious EQ. Most producers I've spoken to consider Rode a solid low-mid range brand, better than some mass exported mics out of the Feilo and Shuaiyin factories (SOME, Feilo have some really nice mics like the SE tube models) but nowhere near industry standards and workhorse brands like AA, 3U, Peluso, Gefell or Neumann. Besides, you didn't say it was a 'high-end' microphone anyway, you said "one of the best studio condensers available today" about a microphone that sees no use in studios. Microphones in a similar price range that actually see studio use are far more 'high end' than the broadcaster (like the Warbler and CM414). As for me knowing what I'm doing, that's certainly up for debate and I definitely wouldn't call myself an expert in the studio but I've spent more than enough time there as an artist, session player, producer and engineer that I've picked up a thing or two, like the fact that microphones that see no studio use whatsoever probably aren't "one of the best studio condensers available". Sloth Sloth's the name, audio gear is the game I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus. Click here for my Microphone and Interface guide, tips and recommendations For advice I rely on The Brains Trust : @rice guru- Headphones, Earphones and personal audio for any budget @Derkoli- High end specialist and allround knowledgeable bloke Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
