smallest mico atx case?
Matt K
I am attempting to build a pc for my sister and she wants it as small as possible while also being inexpensive, it will primarily be used for web browsing a light photoshop work. (~$400 and keep in mind it wont need a graphics card)  I am having difficulty achieving that budget for mini itx due to the premium on mini itx motherboards, does anyone know of any REALLY small micro atx cases that can somewhat compare to mini itx?
There are budget advantages with micro atx.  Lot of cheap cases out there.  If you want full on SFF you’re not really going to find it cheap though.  SFF has a premium just as itx does.
rosewill fbm -06 is pretty small.  It’s not SFF though.
@Bombastinator yeah that's kinda what I expected to hear, just wanted to check if anyone more knowledgeable than me knew of anything.  thanks for the feedback.
The smallest mATX case is probably the Sliger Cerberus - which is about 2/3 of the budget.
SFF & boutique = EXPENSIVE
There are not many good mATX boards for AM4 around and the only one available is ~180-200 bucks
Use the quote function when answering! Mark people directly if you want an answer from them!
Silverstone PS15, the one with no RGB fans should be available for roughly $50 USD, but prices are all over the place right now on various cases.
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
