Help in AlertDialog.Builder text show's in white and completely invisible
NystriX
The title says "Do you wish to leave?" In black
The two buttons says "Yes" and "No" as you can see those are white and completely invisible (you can barely see them if i hold on them), how can i change them to black?
Screenshot_2020-04-02-01-31-15-799_eranmordo_com.thumb.jpg.a878daf4f3b5eb6866c23e91e5eb8373.jpg
Screenshot_2020-04-02-01-31-19-586_eranmordo_com.thumb.jpg.ea41bff1d14344ab7616406a0c905560.jpg
PS2 Fat(JP) : PS2 S Silver(EU) : PS3 Super Slim : Nintendo Switch
Wii(x2) : SNES CE : Xbox One : Xbox 360 S(EU) : PS Vita 2000
AlertDialog alertDialog = new AlertDialog.Builder(this)
                        .setTitle("בטוח שאתה רוצה להתנתק?")
                        .setMessage("יציאה תמחק את הניקוד שלך")
                        .setPositiveButton("כן", new DialogInterface.OnClickListener() {
                            @Override
                            public void onClick(DialogInterface dialogInterface, int i) {
                                DBref.Auth.signOut();// מוציא את המשתמש
                                DBref.CurrentUser=null;// מאספס אותו
                                startActivity (new Intent (gallery.this, login.class));
                                Toast.makeText (getApplicationContext(),"נתראה בקרוב!" ,Toast.LENGTH_SHORT).show();
                                finish();
                        .setNegativeButton("לא", new DialogInterface.OnClickListener() {
                            @Override
                                Toast.makeText(getApplicationContext(), "בוטל" , Toast.LENGTH_LONG).show();
                        }).show();
you prop have overwritten some styles.xml (src/main/res/values/styles.xml)
if i where you i would try to change some colors till i find the right tag, the tags could be something like android:colorAccent | colorPrimaryVariant | colorOnSurface
