Asus Strix X570-F fan headers
ftahir192
I'm looking to build a new system with the Asus X570-F Strix motherboard. This contains only 2 chassis fans at 1A each. It also has a CPU OPT fan header, an AIO pump header, a waterpump header and a M.2 fan header. Each of these are also 1A except the waterpump which is 3A.
Using the Noctua NF-A15 PWM fan as a reference, how many fans could I theoretically connect to each chassis header using splitters? According to this, the fans have a max input current of 0.08A so I thought it's just 1/0.08 = ~12. Does that mean each header can theoretically run 12 fans? This seems way too high so just wanted to confirm if I'm being stupid.
I want to run 6 PWM fans (3 in the front pulling, 1 back and 2 top pushing) but just trying to figure out where I would connect them all and still be able to control them via a BIOS. I'd ideally not want a fan controller but if need be I'll buy one (can pick up a deepcooler 4 fan hub for £10 and then a Y splitter for the second chassis header, or alternatively deepcool's 10 fan header which I think is overkill).
Any help is appreciated as this is where I always get confused with hew builds. Seems like motherboards are coming with less and less chassis headers.
Thanks!
You do have to account for a little bit of efficiency loss, but yea fans really dont use a lot of power. But I would usually go for up to 4 fans on a headers.
I would leave both the PUMP headers alone, since those will runs fans at full speed at all times. But the other 4 headers (so that is incuding the CPU_OPT, but not CPU_FAN, since I assume you need that for your CPU cooler) are free.
So 4 headers, 6 fans, that means you could get some splitters and you're all done.
Do check where the fan headers are, I suspect the M.2 fan headers might be in the middle of the board for example..
So just get some PWM y splitter, 1 headers to three. Get two of those and you're all good, to connect all your fans to 2 headers. That's the easiest thing to do.
M.2 fan headers on this particular board are at the bottom near the front panel connectors thankfully, so would be easy to run a splitter. Would the M.2 fan not run in accordance to the M.2 drive speed? I would have thought it will.
I'm also contemplating the ASUS TUF Gaming Plus which has 3 chassis fans so 3 splitters for that and I'm sorted. Either way, there are solutions now for both via 3 splitters, so thanks.
The x570-f has 2 ARGBA headers and the TUF gaming 1, do you know of a solution to also connect 6 ARGB fans to a single header? I'm wondering if at this rate it's worth going for an ARGB PWM fan hub...
You should be able to select which temp sensor each header uses from BIOS. You pretty much have 5 case fan headers that have odd names and of which one could support more fans. All can be controlled with little tweaking, and you can choose from multiple temp sensors. Like for AIO pump, there's no water temp sensor you could use anyway.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Cool that's good to know, thanks., In that case I'll only need 1 PWM splitter.
Do you know of a decent solution for A-RGB? I'm thinking of buying a 1 to 5 RGB-A splitter but not sure how many fans (i.e. Lian-Li bora) I can connect to a header (rated at 3A)
I don't know if there has been any actual testing about how much amps each RGB fan uses. Usually they come with 3-way splitters or own hubs (Corsairs Node Pro with 6 headers for example). Bora's spec sheet give locked and max currency which are 0.2A and 0.45A. They don't specify which would be one for fans, if any. Fractal Design Prisma gives LEDs current as 0.3A. So using those numbers, you could connect max 10 ARGB fans to single header, but maybe to be sure keep it at 6 fans. If you are using bigger hub or controller, those usually have SATA power which makes these restrictions meaningless.
I'm going to have 6 fans total, and my wraith prism cooler. I have 2 headers, so I assume I should be safe with 3 (or even 4) fans on one, and 3 fans + cooler on the other as I imagine the cooler's fan will be similar output.
What are your thoughts? I don't have a hub/controller as I haven't found one that is non-proprietary at a decent cost
Most likely it'll be fine.
I'll do this by the numbers only. RGB is not my thing.
Okay, thanks.
Yep I've actually decided to scale back and just use 3 RGB fans (provided with my case). I'll use the RGB from my wraith prism cooler temporarily but do plan on upgrading to the Scythe Fuma V2 down the line.
My newly ordered motherboard (ASUS ROG Strix x570-f) has only 2 chassis fans and I have 3 PWM splitters to connect up to 6 fans (only connecting 5 just now). Obviously 2 of the PWM splitters go into the CHA_FAN headers, but I'm not sure where the 3rd is best connected to. I have the following options:
1) CPU_FAN_OPT
2) M.2 fan
3) AIO_PUMP
4) WATER PUMP
I'm not using the optional cpu fan as my cooler (Scythe Fuma 2) has a Y splitter so both fans go into the one header. I can use this for the 3rd splitter but my bios won't let me create custom fan curves for CPU_OPT separately AFAIK (it'll run based on CPU_FAN's curves according to the screenshot above).
I'm thinking of using M.2_FAN as this seems to resemble a chassis fan header the closest - 1A current and no shared control. But not sure about the other 2 (W_PUMP+ and AIO_PUMP). What's the safest one to use here as my 3rd chassis fan header?
Cheers.
The back exhaust fan would be good to go into the CPU_OPT header as it will follow the CPU fan curve, promoting good airflow, at least that is what I personally do, I have a large dual fan air cooler as well.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Use whichever is most convenient. Going with the header closest to the fan can allow for cleaner cables.
*** Threads merged ***
The subject is still same, so no need to post another topic.
