cant fix stutter issues after gpu upgrade
Solved by SavageNeo,
7 hours ago, bmx6454 said:after installing a fresh copy of win10, everything ran waaaay better. games running at way better fps aswell, although fps wasn't the issue. it will still micro stutter, but only when the cpu is between 94%-100%, but most of the time completely stutter free. gpu usage also immediately drops when cpu usage gets high, so definitive bottleneck?? i could be wrong, but the conclusion i'm drawing from this is that its 100% the fault of the cpu, its only running better on a fresh win10 as there is definitely no background programs to take up any cpu?? hoping someone could confirm this before i get another cpu and mobo. thanks in advance.
Try higher resolution since it will put more load on your gpu and less on the cpu
