powershell for loop an array and compare values
Solved by AlexGoesHigh,
Well i guess my googling skills got better, i fixed my problems with this since powershell is diferent from what i know. My code turned out to be useless in the end.
I used this instead to compare the arrays
$arrayOfItemsToCompare | ForEach-Object {
if ($array -contains $_) {
Write-Host $_
