Is stock cooler enough for Ryzen 7 3700x?
Solved by SavageNeo,
3 minutes ago, Hellfire_Helix said:Alright. I'll look into it but would stock cooler serve me well for r7 3700x at stock speeds?
Yes. I have a ryzen 7 3700x and had a stock cooler in it.
When i put my voltage to 1.35-1.375 and core clock to 4.25-4.35 ghz i could run it without issues. So if you have decent airflow a slight overclock might work.
Make sure to test to cpu with cinebench runnin multiple times or aida64 or prime95
