strings into radio buttons
Solved by minibois,
3 minutes ago, Daniboi said:so my task is to make a message box at the end that just says what the user has selected, so if the user picks the colour yellow then it says the colour is yellow
Why not just make button, when pressed it will do this:
string text = "";
if (radiobutton1.Checked == true)
text = radiobutton1.text;
else if (radiobutton2.Checked == true)
text = radiobutton2.text;
// etc. etc...
MessageBox.Show(text);
