Subwoofer choice and "bi-amping" + speaker resistance?
Solved by mr moose,
The A and B terminals is not for bridging or bi wiring. It is simply so you can have main left and right speakers in one room ( A ) and then either a second pair of switchable speakers in the same room or another room ( B ). anything connected to a or b will play the same content and the switch on the front of the amp will only turn on or off the B speakers.
The reason you have impedance's switching is because when you select A and B together it connects the A speakers in parallel with the B speakers so the impedance the amp sees will be half of the speaker impedance, that is why it has a minimum of 8 ohms selectable for A + B (each amp can only handle a 4ohm load)
