Air cooling recommendations (for motherboard)
Motherboard: ASUS Rog Strix B550-F Gaming WIFI 2
I am looking for a decent air cooling tower at a reasonable price. My case has two fans on the top to vent out hot air. Maybe the principle of hot air rising can help with orientation position? There's also one big pancake-sized fan on the case cover instead of a window possibly for maximum airflow. If you can't tell by the picture's watermark I'm not spending money on aesthetics. I'm doing a pure performance build without any RGB for a Linux programming and gaming PC.
Bonus (optional): name some graphics cards and CPU's compatible with my new motherboard
I'm sorry, but you're going about this backward.  We choose our CPU first, then a motherboard to put it on.  The air cooler is for the CPU, not the motherboard.
We need a budget amount as well, so suggest things.  Components cost money 🙂
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
DIL: Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w -NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Oh, explains a lot. I'm new to PC building. I know that the air cooling is for the CPU, I'm not that  dumb. My brain associates air-cooling like with the VW flat 4 or small engines so I hope you can excuse my confusion of some terminology. I opted for a full-sized ATX case because I want to make sure my motherboard fits.
Any tips on airflow? 🙂
Yes, have roughly the same fannage intake vs. exhaust.
Are you looking to build a PC?  Do you have a total budget?  Resolution you play at?  What games?  Other uses?
Or just curious about airflow and cooling?   Short answer for CPU cooling... Phantom Spirit 120 or Peerless Assassin for budget, 360mm AIO for hard to cool CPUs like the 13900K/14900K.
OnePlus:
Other Tech:
I don't have a specific budget. the case itself was only $26 and the motherboard (brand new) was $180. I don't have a specific budget other than save up to gradually build up my frankenstien computer one part at a time. I think I can get a power supply from another thrift store that has a high enough wattage capacity for almost nothing.
You're lucky you can get this stuff at thrift stores. The thrift stores near me are all used up clothes and dishware that people only bought because they were on drugs.
you actually have a very good point... a cpu aircooler will help to cool parts of the motherboard, especially the VRMs whereas a watercooler will do nothing for those parts ... its why many people with watercooling have "mysteriously" high temps - also on their gpu in some cases.
That said, what in the world is this pc case...? is this just an example or?
If you want really good cooling i recommend an open air pc case, not a "test bench" and actual case.
such as (example)
oh you already... well you gotta do what you have to i guess... not sure what the specific question is but you should do ok with a semi decent aircooler .
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
*Cough cough* - VRM fan(s) on the water block - *cough cough* - Arctic, SilverStone, EnerMax, etc all offer models with them.
You have the InWin Maelstrom (Overclockers Review) Case. Have you actually tried mounting your mainboard inside it? The review says that not all will match the location of the rear I/O hole. It's a nice but venerable case.
You need to provide the mainboard info because that will entirely determine which CPUs you can consider. Generally, it is correct to choose a CPU, then the mainboard, and then you can choose the case. However, if you delay the case, you can choose big parts like the GC and cooler, which will further limit the options for cases.
Specifications:
Material
SECC (0.8~1.0mm)
Expansion Slots
7 Slots
Thermal Solution
Front: 12cm Fan x 1
Rear: 12cm Fan x 1
Top: 12cm Fan x 1 (Maximum Supports 12cm Fan x 2)
Side: 22cm LED Fan with switch x 1 (Maximum Supports 12cm Fan x 6)
Water-Cooling Hole Ready
Front I/O
4x USB 2.0
2x e-SATA
1x Firewire
HD/AC’97 Audio
External Drive Bays
5x 5.25”
Includes FDD Cage (5.25” to 3.5” adapter)
Internal Drive Bays
6x 3.5”
Motherboard Support
ATX
m-ATX
E-ATX
Power Supply Support
ATX 12V
PS2 or EPS Power
Features:
  • Great expandability
  • User friendly ergonomic and mechanical design
  • Superior acoustic and vibration solution
  • Revolutionary high efficiency thermal solution
  • Luxurious exterior and interior painting
Based on these specs, you can't really effectively use any CPU that gets very hot, like AMD's newer ones, and the Intel i7/i9s, especially from gen 12-14. This case is not going to work well for watercooling unless you do a custom loop if I'm not mistaken.
What you really need is new build advice, not cooling. This sub-forum is for cooling and, since you have an antique case and no CPU, no cooling advice can be specific.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
Specifications:
Material
SECC (0.8~1.0mm)
Expansion Slots
7 Slots
Thermal Solution
Front: 12cm Fan x 1
Rear: 12cm Fan x 1
Front I/O
4x USB 2.0
2x e-SATA
1x Firewire
HD/AC’97 Audio
External Drive Bays
5x 5.25”
Internal Drive Bays
6x 3.5”
Motherboard Support
ATX
m-ATX
E-ATX
ATX 12V
PS2 or EPS Power
Features:
If the case doesn't have the right mounting holes I can always use some self tapping screws. What do you mean by antique case? Looks pretty modern by my standards.
You're looking for more than just a CPU cooler, so I moved your thread to New Builds and Planning.
Thanks
Circa 2009. In tech terms that is nearly antique. 😄
Have you tried mounting the motherboard in the case? Based on https://www.overclockersclub.com/reviews/inwin_maelstrom/3.htm#&gid=1&pid=39668 I'm not sure it will be a comfortable fit.
My Motherboard has the ATX mounting holes. I got the case because it's a full-sized ATX tower and not a micro-ATX
Yes, that is obvious.
I get the feeling you are just floundering around here.  Buying piecemeal like that without a full understanding can lead to an oops or two later.  When you see a good deal on a part, buy it, then months later realize it won't work with what you bought previously.
I highly urge you to post here BEFORE buying anything else, to make sure it all works together.
OnePlus:
Other Tech:
I found that out the hard way. But I did research what kind of case my motherboard needed before buying it. I bought a small Dell tower that was too small for my motherboard and thought I'd repurpose the old Dell computer as a server later in the future.
i mean I knew you could always just throw a case fan in the direction,  but most people wouldn't know or don't want to because of "aesthetical reasons"...
to me its just one of many downsides of watercooling besides not really liking the borg cubus optic...  tbh i think the pump sounds alone would drive me crazy haha.
and oh i didn't know its an inwin case, that explains why it looks so impractical  (inwin case owner here btw 😉 )
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
yeah just for starters check if the mobo actually aligns with the cases I/O etc... dont need to build anything... just put it in for a test
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
it looks like straight outta the 90s 😅
mind you I almost like how it looks, the handles... the different shades of green... just wow!
also as for airflow,  yes "hot" air rises, but this is still a pc not a crematorium... you have to think of pc cooling more like a wind tunnel, fast in fast out - the faster you get the "hot" (its usually actually more like lukewarm lol) out the better... that's why most cases have front intake fans and a rear outtake fan... also a tower cooler usually blows in the same direction so that in itself is already almost ideal...
now, as with your case, and many "modern" "airflow optimized" ones, it has a lot of other openings but none seem strategically well placed, depending on fan setup that will create a lot of turbulences and force warm air to stay longer in the case than it should... a problem with many "airflow" cases, they go more for optics than common sense aerodynamics... and especially older ones like yours.
it isnt unusable by any means but if "airflow" is one of your priorities it's just less than ideal.
(posted pic above of an actually airflow optimized case, the type is called "open air" because that's what it is) 🙂
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
I don't have any problems using older cases. Whatever gets the job done, I guess. I'll send pics when my case arrives in the mail so you can guide me a little airflow wise. All I know about air-cooling besides CPU stuff is stuff regarding your lawn mower's engine and not much else really. I personally don't like the look of "minimal" cases that look more like fish tanks, I prefer metal over glass any day of the week. On the bright side I have somewhere to install a CD-ROM drive so I can play some old Windows PC games collecting dust.
Very few modern cases have drive bays anymore - at least not the kind that are for external access. That case is about 15 years old so, yes, it's old. 😉
We can't properly advise you on airflow until the PC is assembled. Airflow is tricky because of the huge variability from PC to PC.
That's why I said I'll send pics to show y'all. I plan on having both SSD's and regular HDD's I have lying around to maximize my storage. I call my in-progress build "The Tower of Jank"
It's like I live a long drive away from where richer neighborhoods dump off their old computer hardware like it's nothing. I got an old Dell mechanical keyboard for only $3 and I salvaged a an old Dell monitor for free from an e-waste pile.
