Please look at my build and inform me if theirs any problems and or upgrades worth it Thanks!!
Go to solution Solved by PC HEROES,
49 minutes ago, sweshy said:
thanks alot!
Hello... I thing this might be a better bet for you. Did you need 2 Monitors or was that just a mistake? I only included one but why only shoot for 1080p when you could get a 1440p Monitor which is where the sweet spot is for Gaming? Also I picked a Monitor that has Speakers because I can know from experience that using a Headset 100% of the time to listen to things can really aggravate your Ears if you use them all the time.
The WD Blue M.2 you had is a bit too cheap so I got you a slightly better one. I like the NZXT H6 Flow too but when you have to add so many extra Fans to it it becomes very costly. So I switched it for the Phanteks XT View, it's the same type of PC Case that looks like a Fish Tank and it already comes with 3 included ARGB Fans. I added 2 more that will go on Top of the PSU Shroud and the AIO will go on Top of the PC as always.
Have a look and let me know what you think. You can contact me on Discord here: Wizardsnapper#2772 if you would like to get into further detail.
https://pcpartpicker.com/list/vpWjFs
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($339.99 @ Amazon)
CPU Cooler: Thermalright Aqua Elite V3 66.17 CFM Liquid CPU Cooler  ($56.90 @ Amazon)
Motherboard: Gigabyte B650 EAGLE AX ATX AM5 Motherboard  ($144.21 @ Amazon)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($106.99 @ Amazon)
Storage: TEAMGROUP MP44 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($123.99 @ Amazon)
Video Card: XFX Speedster MERC 310 Black Edition Radeon RX 7900 XT 20 GB Video Card  ($699.99 @ Amazon)
Case: Phanteks XT View ATX Mid Tower Case  ($117.53 @ Amazon)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Amazon)
Case Fan: Phanteks M25-120 PWM D-RGB 84.26 CFM 120 mm Fan  ($19.41 @ Amazon)
Monitor: ViewSonic VX2718-2KPC-MHD 27.0" 2560 x 1440 165 Hz Curved Monitor  ($179.99 @ Amazon)
Keyboard: RK Royal Kludge RK61 Bluetooth/Wireless/Wired Mini Keyboard  ($49.99 @ Amazon)
Mouse: HP HyperX Pulsefire Haste Wired Optical Mouse  ($39.99 @ Amazon)
Headphones: SteelSeries Arctis 1  Headset  ($87.99 @ Amazon)
Total: $2116.37
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
Pretty good. I would probably change the SSD out for something a bit cheaper as you won't notice an improvement from a 990 Pro vs. something cheaper like an SN580, plus the 990 Pro has had some quality control issues and I wouldn't 100% trust it. I'd also consider dropping the AIO down to a $35 air cooler as the 7800X3D really isn't that hard to cool, though if you really want it for the aesthetics that's fine. Swapping the case out for the H6 flow instead might be a good idea too since it's a very similar aesthetic case for ~$50 cheaper, just a bit smaller (though you're not really using the extra space). Doing all that might let you upgrade the GPU to a 7900 XT rather than the GRE.
https://pcpartpicker.com/list/tNyZYN
I'm not going to comment on the peripherals since they're not an area I particularly follow. They look alright enough, though trust what someone else says about it.
thanks alot!
thanks alot!
Total: $2116.37
Total: $2116.37
Thanks Lots! https://pcpartpicker.com/user/Sweshy/saved/fQpL7P
Total: $2116.37
and the second monitor is for things such as discord and music
You are very welcome. I have been doing this a VERY VERY long time. It's my most favorite thing to do, Build PCs.
I noticed that the second Monitor you added was out of stock so I added one that was in stock, same Brand as the first one.
https://pcpartpicker.com/list/RYzGCd
CPU Cooler: Deepcool LE720 85.85 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Monitor: ViewSonic VX2418C 24.0" 1920 x 1080 165 Hz Curved Monitor  ($124.99 @ Amazon)
Total: $2294.45
Total: $2294.45
thanks again!
2 minutes ago, sweshy said:
thanks again!
Anytime... If you have any questions please ask. If you need any help before, during, or after the PC is Built then please contact me on Discord as they have Free Text, Voice, & Video Chat. I Wish you the Best Luck!!!
Budget (including currency): ~1500$ for just the pc ~2000$ for all (moniters, mouse, keyboared) (i am a little over budget so im just asking if this is good config for ~2000$
Country: USA
Games, programs or workloads that it will be used for: from Tarkov to roblox
Other details https://pcpartpicker.com/list/MXqVpB
Country: USA
Lose the AIO, the x3d chips don't need them, and DeepCool is sanctioned by the US so buying it may not be allowed.
Do you have a Microcenter nearby?
You can shave a lot by some smart choices and lose no performance.  Btw, why are you buying a 2nd monitor like that one?  if it's for Discord and other crap, just get the cheapest you can find, sub $100.  Then you'll be under $2000 nicely.
PCPartPicker Part List
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: Gigabyte B650 EAGLE AX ATX AM5 Motherboard  ($144.99 @ Amazon)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($114.99 @ Amazon)
Video Card: Gigabyte GAMING OC Radeon RX 7900 GRE 16 GB Video Card  ($549.99 @ B&H)
Case: Phanteks XT View ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Amazon)
Case Fan: Phanteks M25-120 PWM D-RGB 84.26 CFM 120 mm Fan  ($19.62 @ Amazon)
Monitor: MSI MAG27C6X 27.0" 1920 x 1080 250 Hz Monitor  ($169.00 @ MSI)
Headphones: SteelSeries Arctis 1  Headset  ($74.99 @ Walmart)
Total: $2041.03
Generated by PCPartPicker 2024-06-15 10:35 EDT-0400
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
DIL: Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w -NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Total: $2041.03
That cooler won't clear that RGB RAM and that Gigabyte Eagle board comes with the old school 1G LAN.
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: *MSI PRO B650-S WIFI ATX AM5 Motherboard  ($145.12 @ Amazon)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($94.97 @ Amazon)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($104.97 @ B&H)
Power Supply: *be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.90 @ Amazon)
Total: $1964.79
Generated by PCPartPicker 2024-06-15 10:43 EDT-0400
[ Threads merged ]
One thread per build please. That way all the discussion about it stays together.
Total: $1964.79
Is old school 1G Lan bad?
OnePlus:
Other Tech:
2.5G LAN > 1GB LAN
Just now, Why_Me said:
2.5G LAN > 1GB LAN
Maybe, in a technical sense.  But it's more like nvme drives.  More isn't better, it's just more.
How often do we need more than 1g lan?
OnePlus:
Other Tech:
Total: $1964.79
https://pcpartpicker.com/list/7YVXcH
You can save a few dollars while getting a better case out of it. Replace the 140mm exhaust fan that's included with this case with the 140mm ARGB fan down below if you desire the full effect.
Video Card: Sapphire PULSE Radeon RX 7900 XT 20 GB Video Card  ($689.99 @ Newegg)
Case: *Lian Li LANCOOL 216 RGB ATX Mid Tower Case  ($99.99 @ Amazon)
Power Supply: *be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.90 @ Amazon)
Case Fan: *Lian Li UNI FAN SL V2 77.6 CFM 140 mm Fan  ($29.99 @ Amazon)
Total: $2049.80
Generated by PCPartPicker 2024-06-16 12:49 EDT-0400
A better look at that case.
https://lian-li.com/product/lancool-216/
