5v RGB Hub
zapdroid
Hello everyone, I'm looking to get some more RGB in my PC but my Gigabyte motherboard's two 2A headers aren't enough. I've seen a couple of people reference this first product, and I'm also looking at a second similar product.
https://www.amazon.ca/Mwergkou-Splitter-Magnetic-Standoff-Controller/dp/B07VYLF69W/ref=sr_1_4?keywords=argb hub&qid=1582826119&sr=8-4&tag=linustechti06-20
https://www.aliexpress.com/item/4000327122574.html?spm=a2g0o.detail.1000014.8.4b2339764BJF6g&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.13338.133222.0&scm_id=1007.13338.133222.0&scm-url=1007.13338.133222.0&pvid=ac60cbba-28cd-444f-b6c4-8d8131d54587
Has anyone actually used these and found them to be reliable? Is there any risk of them damaging my PC or RGB products if they fail, or will only the hub itself stop working? I don't value addressable RGB enough to spend much more, which is why these seem to be my only options.
there a risk with anything you do with your pc.
other option is to make your own adapter and put power from the psu.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
