3 minutes ago, NineEyeRon said:
Once you go Noctua you don’t go backtua
You sure? I have started going with the arctic p12/p14 and/or p120/p140s. The are about 1/3 the price and have almost identical specs.
I use to spend the 20-25 per fan, but since I discovered these gems I have never purchased another noc or ML fan.
https://linustechtips.com/topic/1155124-fans/#findComment-13293159
35 minutes ago, iamlegs said:
so i fixed 2 of my fans but for some reason my cpu got hotter anyone know why?
31 minutes ago, iamlegs said:
1 i dont know?
2 bought some fan hub thing
3 34C-50C  idle
4 dont know
Please give some more info. "bought some fan hub thing" is definitely not enough info to judge anything on.
Likely the fan hub has a different fan curve as compared to your previous setup.
https://linustechtips.com/topic/1155124-fans/#findComment-13293246
Noctua Redux line fixed that issue, super competitive price wise.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/1155124-fans/#findComment-13293255
4 hours ago, iamlegs said:
could anyone help me? and not talk about something that dosent belong in this threat?
The idle temps are normal, how are temps when you sre stressing system?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1155124-fans/#findComment-13293905
43 minutes ago, iamlegs said:
i dont understand sre stressing system
It means when you are actually using it. Like gaming, 3D modelling, video editing. Or actually running stress test like OCCT or Aida64.
https://linustechtips.com/topic/1155124-fans/#findComment-13302323
