New PC Build, System Locks up and previously BSOD
How long does it last before locking up? If you can, download the drivers for your card from Nvidia's website onto a flash drive, and as soon as your system boots to desktop (if it can do that) install the drivers.
4 minutes ago, Bootsy said:DPC_Watchdog_violation
This code can be caused by faulty drivers, incompatible hardware, conflicting programs (like two antivirus softwares running at once), or SSD firmware incompatibility / corruption.
If you can't install drivers, or that doesn't help, try removing all but one stick of RAM, or just running 2 sticks in dual-channel (in alternating slots on the motherboard). You MIGHT (though I can't tell for sure) have bad RAM. If changing RAM helps, you'll need to test each stick individually through the Memory Diagnostic tool. It's a built in troubleshooting tool, just open the start menu and search for it, and run it as an administrator. Select the option to restart your PC and it'll check the stick for hardware issues. If that doesn't help, try reinstalling windows on your storage drive. That could tell you if you have a bad M.2
