Which case for my first build?
Solved by TVwazhere,
1 minute ago, sponkaa said:I thought about getting the MB511. A big plus for me are the 4 included fans. I also fancy the P360X by Phanteks, so my budget is around 80USD.
Fractal Design Focus G
Cougar MX330
Phanteks P400A RGB
Cooler Master Master Box 5, MB500, NR600
Corsair SPEC-04
Rosewill Spectra C100
Thermaltake Versa J24 Tempered Glass (seems to be overpriced in the US right now)
Metallic Gear Neo Air
Notably, only the Versa J24 and the Spectra C100 also come with 4 fans. The rest only have 3, 2, or 1 included fan.
