Why does my laptop keep overheating?
Solved by saintlouisbagels,
Give us more information.
Is there proper ventilation? Are you running the laptop while it's still in its plastic wrap?
Are you using it on your lap and covering the intake vents?
Is it an extremely old laptop and the thermal paste has gone bad?
How do you know it is overheating? Is the laptop shutting down?
A hot laptop is not an overheating laptop. It means it's a hot laptop.
Is it throttling performance - meaning, are you losing FPS speeds after a while?? That is normal and expected for a laptop.
