i'm running a ryzen 5 3600x and the voltage/frequency are extremely high. voltage stays around 1.4-1.44V (which i know isn't safe) and the frequency is always at around 4300mhz (even on idle, with 3% cpu utilization). if i set the power plan to power saver then it goes down and uses the minimum value (5%) and my cpu will be stuck at 0.9V with 2200mhz. now, either balanced or high performance plans will always keep my cpu on 1.4-1.44V with 4300mhz. i will most likely set the voltage to 1.325 in ryzen master but i also don't want it to be running at that on idle (or on maximum frequency). the voltage also seems to be giving me really high cpu temps. all this data was monitored using hwmonitor, hwinfo and cpu-z. does anybody have a clue on what could be causing this? could this be faulty hardware since i had some other problems before formatting and resetting the bios? thanks
https://linustechtips.com/topic/1146391-crazy-cpu-voltage-and-frequency/
don't set a fixed voltage for zen 2, let pbo do its job, just set a -.05v offset in bios.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
nah 1.4-1.45 all fine. Its peak voltage so its like just 1 core spiking and being greedy. Dw about it.
Cant see an issue about it being at max frequency thats normal. As long as temps are fine and fans not loud its not a problem.
What temps are 'High Temps'.
What are your temps? And what are you using to look at the clocks and volts?
Ryzen will automatically boost the Voltage in low core/threadcount workloads, in order to boost performance in those instances, which causes no damage to your CPU. Once you pin it in something like P95 or Cinebench you should notice that the voltage drops to somewhere in the 1.2-1.3V range.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Those high voltages are fine if the CPU isn't under significant load.
And if you do use a negative offset then you'll want to compare with benchmarks (before and after) to make certain the CPU doesn't begin clock stretching as it won't reflect in monitoring software.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
that's only for boosting lightly threaded work. In all core workloads it shouldnt use more than 1.35V, usually 1.3V
Use 1usmus' power plan if you want better clock speed adjustments
Desktop benching:
Cant see an issue about it being at max frequency. As long as temps are fine and fans not loud its not a problem.
that's one of the issues, i'm getting really high temps. right when i got this pc, before i locked it to base clock speed i got up to 94C running a single benchmark. also, i'm afraid that the fact that the power plan settings aren't working properly and the cpu in general isn't working as expected hides some underlying cause that will give me problems in the future (op is a bit of an overthinker).
hwmonitor, but it's the same in hwinfo. my temps are around 75-80 only at roughly 40-60% usage. whenever i change power plan and it lowers to 0.9V and 2200mhz the temps stay at 45-55 with the same usage.
more detail please.
94c in a benchmark ok is that stock? you could just have bad airflow.
What about idle? What are temps?
my 3600 is on a h115i liquid cooler and i get 45c idle.
18 minutes ago, The Torrent said:
more detail please.
it is stock, and i do have bad airflow, but i didn't imagine that either of those would result to numbers this high. idle temps are around 55.
That’s fine.
airflpw is your problem. A 3600 with stock cooler and bad airflow can easy hit 94.
the voltage is fine the clock is fine.
try get some more fans sorted.
13 minutes ago, GoldenLag said:
Seems like normal boosting behavior lf a modern desktop CPU.
Low current  scenarios the CPUs use high frequency to be more responsive. The high voltage then isnt harmful.
well i don't understand much about computers and hardware in general, but my expectations were for the usage to be proportional to the frequency, voltage and temps. why is the high voltage not harmful when the frequency is also high? and couldn't high frequency and voltage even though it's not needed shorten my cpu's lifetime or cause other problems?
That’s fine.
thanks, all i really need is an exhaust fan in the back i think. i planned on getting one right after i got the pc but i stumbled across these issues and decided to not get it until i knew for sure what was causing them lol
It's safe when the CPU is not heavily loaded which also means there is a low current.
High voltage combined with a lot of current would be harmful regardless of frequency. That's why we have LLC, power limit, and Vdroop to prevent this.
21 minutes ago, The Torrent said:
That’s fine.
also, all the cores are above 1.45V right now
well whenever i play a heavier game it will be heavily loaded, so will my voltage drop then?
Not in low current scenarios.
Like i answered in my original answer.
Because in a non-power limited PC like a fulltower, it makes the system more responsive.
In a laptop that would be the case. And when the CPU does go into resting mode that is the case, otherwise its nit
its fine
heres mine i just turned the cpu on.
I phoned a few places up and asked a while back they all said if auto is giving high voltage if temps are fine its all ok.
