Hi guys
I'm a complete noob with networking and NASs and such and I really need your help.
I have an old computer with 2gb ram (can't upgrade) and a core2duo e6600
My main computer has a 1tb and a 3tb hdd in it alongside a boot ssd, but I really hate the noise the hard drives are making, so I want to make it so that I can access my HDDs via ethernet on that old PC.
I have windows 7 32 bit on it right now,but I can't seem to get fileshare to work from that PC to my main rig. It won't give me access.
I put FreeNas on a usb drive and tried to boot off that so I can install it, but the old PC just won't do it. Just to make sure, I've tested the boot drive on my main rig and it worked just fine, so I guess that's not going to work.
If someone here could help me configure that PC as a nas I would be very grateful, but as I already said, I am a complete noob and I don't know what to do.
Thanks in advance for your help.
https://linustechtips.com/topic/1145562-noob-needs-help-with-nas/
16 minutes ago, Yasin40 said:
noob
FreeNas
These two things don't really go together.
Those may not meet the minimum system requirements of FreeNAS
https://www.engadget.com/2012/02/01/how-to-set-up-a-home-file-server-using-freenas/
But if you really want to try, use this:
https://www.tecmint.com/installation-of-freenas/
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
With specs that low you're going to want to roll with a very light-weight distribution of Linux or something like FreeBSD (what FreeNAS is based off of).
I wrote a guide on setting up Ubuntu server but the recommendation is 4GB of RAM. It may work with 2GB but you could probably pickup a little more for really cheap or find a lighter distro of Debian. Otherwise the instructions should be near identical.
I managed to set up FreeNas via CD and put it on a 8gb usb stick.
I connected the 3tb and 1tb hdds from my main rig to the FreeNas PC. What do I do now?
I have LOTS of stuff on both drives. I'm afraid they'll get wiped if I do something wrong. It says that if I create a new pool the disks will be wiped.
What should I do? I don't want to lose all my stuff
Just now, Radium_Angel said:
Why don't you have backups?
I only have those 2 drives as my mass storage. I just want to be able to access the data that's on them via network so I don't have to hear the HDD noise in my desktop. Is FreeNas not a good way to do this?
FreeNAS uses ZFS. Windows uses (usually) NTFS. You can import the data on a NTFS volue to a ZFS pool but you cannot directly mount and use a NTFS volume as a pool. You'll need a new drive to put all the data on or a backup to where you can restore the data after setting up the pools.
So I would another 1 and 3tb hdd?
That sounds rather inconvenient :/
Would it be better for my usecase to just install linux on a different smaller hard drive and share the 1 and 3tb hdd as network folders?
No. You could use one bigger hdd just to hold all the data together. Use folders or datasets to organize it all.
That's the standard when switching entire platforms. There are some distros that allow the read and writing of NTFS volumes but I wouldn't trust them with everything without proper backups. Better to switch over to ZFS or EXT4 or EXT3.
2 hours ago, Kamvas said:
If you dont want to lose your data in both drives why dont you make them both shared in you old computer and leave that computer in a place that you wont hear it? and dont try to make your life miserable... xD
I thought FreeNAS needed 1 gig of ram per TB of storage, no? I think you would be way better off shucking a 4TB or 8TB external drive (Cheaper per TB) and running something lightweight like open media vault
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
i meant to use the old pc with windows and make those drives as shared and use them via local network... so he will avoid buying a new hdd to backup up all of his data and then config a freenas or whatever only for those 2 drives.... lol... and finally if he wants to experiment with those OS he can do it with some used hdds and make them work before do anything critical and lose his files...
FreeNAS says that it requires a 64-bit system and a minimum of 8GB of RAM...unless you're running like version 9.4 or whatever the last one that supported 32-bit was.
What specifically is the problem you're experiencing with the Windows 7 machine, and trying to get filesharing to work. Is your plan to transplant the 1TB and 3TB drives from your main machine into the Windows 7 machine? Do both machines have filesharing enabled? Are they both set to a 'private' network? Can you ping one from the other using CMD or something?
Honestly, your best bet in the short term is to get an external HDD that's like 4TB or so, and just manually copy the data across, so at least you have an onsite, recent backup. As far as I'm aware, you can't set up the disks in FreeNAS without wiping the drives, that's just how it be.
Desktop : AMD Ryzen 7 7800X3D - Sapphire Pulse Radeon RX 7900 XTX - Gigabyte X670 Gaming X AX v2 - 2 x 16GB Crucial Pro DDR5 @ 6000MHz - 2 x Crucial 2TB 2.5" SATA SSD - Seagate 3TB HDD - Gigabyte 850W - DeepCool AK620 Tower Cooler - Thermaltake Chaser A71 - Kogan 35" Ultrawide 2560 x 1080 144Hz - Ducky One2 w/ MX Browns - Logitech G502
Media : Intel Pentium G4560 - Gigabyte B250N-Phoenix-WiFi - Crucial 12GB @ 2400MHz - Asus GeForce GT1030 - 120GB SATA SSD - Corsair SF450 - Fractal Design Node 202
ITX Server Intel Pentium Gold 5400 - Gigabyte H370 WiFi - Crucial 8GB @ 2400MHz - Crucial 240GB SATA SSD + Seagate IronWolf 8TB -  Cooler Master S Series 400W - Cooler Master RC-110 mITX
X99 Server : Intel Xeon E5-2670 v3 (12c/24t 3.1GHz boost) - Huananzhi X99-QD4 - Crucial 32GB @ 2400MHz - nVidia GTX 645 - SiliconPower P34A80 1TB NVMe SSD - SilverStone Fara R1 V2
