Will my laptop run No Man's Sky?
Solved by RadiatingLight,
4 hours ago, iM8Pizza said:Thanks for the reply. I'd like to correct the spec on the second machine, it's actually Nvidia 940MX, would that suffice?
Probably not.
If it does, then it'll be at barely-playable framerate at lowest settings
you could always lower resolution to 720p or something, and then it probably could.
remo233 ·
Posted in CPUs, Motherboards, and Memory4 -
RTX 3090 ·
Posted in Programs, Apps and Websites1 -
7
7
porina ·
Posted in New Builds and Planning19 -
Rothinsky ·
Posted in Troubleshooting2 -
skayqz ·
Posted in Graphics Cards7 -
