Switching from AMD to nVidia, need help with drivers
Solved by Semper,
If you want to remove all traces of your previous drivers, use DDU.
It can be done with the respective driver uninstaller, but it does leave traces, which have been known to cause issue in the past in some instances.
For me, it's an extra five minutes, it's worth using DDU just to minimize any potential issues.
remo233 ·
Posted in CPUs, Motherboards, and Memory4 -
RTX 3090 ·
Posted in Programs, Apps and Websites1 -
7
6
porina ·
Posted in New Builds and Planning16 -
Rothinsky ·
Posted in Troubleshooting2 -
skayqz ·
Posted in Graphics Cards7 -
Ricodotsh ·
Posted in New Builds and Planning15
