gtx750ti I want some help
Solved by Curious Pineapple,
On 1/7/2020 at 4:18 AM, saniazam said:well my eps adators do not work at all the gpu wont even start at least i want to try it can u help
EPS connectors are for CPU power headers. You really are limited to having an external power supply, pushing your luck with molex adaptors, replacing the entire machine or selling the card and getting one that doesn't require supplementary power.
