It's finally DONE, Was hard, But it's done and No regrets were made :) , Here it is
CPU: Intel 9900k
Motherboard: Asus Prime Z390-A
RAM: 32GB (x4 8GB Modules) Corsair Dominator
VideoCard: Asus Nvidia 2080ti
HDD/SSD: 1TB M2 Samsung EVO 970
Case: LianLi O11 Dynamic (White)
Radiator: x1 Corsair Hydro X Series XR5 360
Fans: x6 Corsair LL120 RGB
Tubing: Thermaltake PETG ID: 13mm OD: 16mm
Fittings: Bitspower Throughout
 Waterblocks: CPU: EK-Velocity RGB (Nickel+Plexi) VideoCard: EK-Vector RTX 2080ti w/ Nickel Backplate (Nickel+Plexi)
Reservoir: Bitspower Touchaqua Sedna Front Plate
Options: Corsair Commander Pro, Corsair RGB Controller, Custom Sleeved Cables for CPU, ATX and PCI-E
Every item was meticulously cared for during the build, and all leak tested. I ran burn-in tests on the CPU/RAM/Video Card, with zero errors. What do you all think?   pc1.jpg.ec953bec996a88c75d306412a4de5296.jpgpc2.jpg.bf88ac9cd0fa3aaed3d2615a29cb989e.jpgpc3.jpg.801a08938e18460dda0a9b7abd35e207.jpgpc4.jpg.a9ddcb0e2d202a76aa690869c15e9223.jpgpc5.jpg.5a3ef5d5970d133f957b9d4781c37109.jpgpc6.jpg.0cba88b9510ef09aa553cb67528067ef.jpg
My custom loop 5000$ PC:
 CPU: Intel i7 9900k Motherboard: Asus Prime Z390-A RAM: 32GB (x4 8GB Modules) Corsair Dominator VideoCard: Asus Nvidia 2080ti HDD/SSD: 1TB M2 Samsung EVO 970 Case: LianLi O11 Dynamic (White) Radiator: x1 Corsair Hydro X Series XR5 360 Fans: x6 Corsair LL120 RGB Tubing: Thermaltake PETG ID: 13mm OD: 16mm Fittings: Bitspower Throughout Waterblocks: CPU: EK-Velocity RGB (Nickel+Plexi) VideoCard: EK-Vector RTX 2080ti w/ Nickel Backplate (Nickel+Plexi) Reservoir: Bitspower Touchaqua Sedna Front Plate Options: Corsair Commander Pro, Corsair RGB Controller, Custom Sleeved Cables for CPU, ATX and PCI-E
https://linustechtips.com/topic/1141932-5000-custom-loop-water-cooled-pc/
None of the pics show for me :(
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
No images came thru for me.
Also, you're sounding like a Youtuber with the price in the title.  Not sure if that is meant to impress or not, I prefer to see good work done, regardless of price.
When the pics come thru, will see how she looks.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Should work now
Just now, jakeslayer9091 said:
Should work now
Very clean!  Nice job.  Color scheme is good
That definitely looks good.
I'm assuming most of the cost were the fans?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
Nah, The fans were 200$, But the water cooling stuff, and all the extra stuff I put in probably costed like less than half of the build
Fans are probably only about $280-$300 of the entire system regular price. I would reckon the majority of the build cost is that 2080Ti. I have pretty much the exact same hardware in my Cosmos Sv2 build. I gotta say I love how different the system looks from my own.
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
Nice rig but it kills me when people spam the price of their setup everywhere like it's the coolest part.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Yeah, no.  I was joking.
But you know someone is going to ask the cost so might as well get it out of the way up front.
Plus I think something is off with the costs.  I built a 9900k + 2080 Ti build last year with a better motherboard, Corsair ML fans, EK blocks/radiators/fittings and it was maybe $3k.  Not sure what makes up the $2k difference.
Gaming - AMD TR 3970X | ASUS ROG Zenith Extreme II | G.SKILL Neo 3600 64GB | Zotac Nvidia 2080 Ti AMP | 2x Sabarent 1TB NVMe | Samsung 860 EVO 1TB SSD | Phanteks Enthoo 719 | Seasonic Prime Ultra Platinum 1000w | Corsair K70 RGB Lux | Corsiar M65 | 2x ASUS Rog PG279Q | BenQ EW3270U | Windows 10 Pro | EKWB Custom loop
ITX - Intel i7-10700k | Asus ROG Z490-I Gaming | G.SKILL TridentZ RGB 3200 32GB | EVGA 2080 Super| Samsung 970 Evo 1TB | Samsung 860 Evo 1TB SSD | NZXT H1| Windows 10 Pro
HTPC - Intel i9-9900k | Asus ROG Maximus XI Code | G.SKILL TridentZ RGB 3200 32GB | EVGA 1070 | Samsung 970 1TB | WD Blue 1TB SSD | NZXT H700  | EVGA G3 1000W | Corsair H150i | Windows 10 Pro
Servers - SuperMicro 846 | 2x 2695L V2 | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 24 x 6TB | FreeNas - SuperMicro 826 | 2 x 2695L | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 8 x 10TB | 847 24 x 1TB SSD | Windows Server 2019
Work - Dell XPS 15 9560 | i7-7700HQ | 32 GB RAM | 1TB NVMe | 4k dsiplay
I built his exact rig, and since he didn't give much detail I went all out on RAM choice, and PSU. And it totaled under 3k. He spent apparently ~$1200 on cooling? Possible?
It also grinds my gears that he couldn't have bought a fuckin PRO cablemod kit with some damn combs.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
3 minutes ago, Statik said:
  Total $2833.82
  Generated by PCPartPicker 2020-01-04 20:40 EST-0500
$5000 - 2833 = $2167 which is a lot for water cooling parts.  And I guess I spent more than I realized but still not that much including a custom loop.
Oops I did horrific math. But yeah 2.2k on watercooling is bullshit. If I was motivated I could probably price out that loop and prove him wrong.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
When it's the very first word in the title, it says what it's intended to say.
It's an expensive, fantastic looking rig.  Can it be done cheaper?  Very much so.  Does the OP want us to know how much he spent on it, very much so.
Is it gorgeous?  Very much so.
Each of us can take from it what we want.  I think it's nice.
OnePlus Ecosystem:
3D Printing:
I'm not saying it's not nice, I'm saying it's not worth 5k. And it's cheese dick that he's throwing around the price everywhere like it makes him cool.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
Ok, I don't know why you're getting so bent out of shape about his title so let me play defender a little here. First off, I only see the price once in his title and once in his signature with a share link to this thread and by the nature of the forms once again in the share link. Next, who knows if he's including the price of the entire setup not just the tower. In which case yes maybe they should added "Setup" in their title and took pictures of everything.
Also, not everyone has access to the absolute lowest prices that are listed on pcpartpicker. What if they live in a country where they charge an obscene amount for pc parts compared to the US prices? For example, the 9900k is apparently $780 in Australia according to this: https://www.shopbot.com.au/pp-intel-core-i9-9900k-price-557526.html I myself ended up paying $719cad for my 9900k. Yea I could've gotten it a bit cheaper but I wanted to get it and the motherboard from a physical store.
With my own main rig tipping the scales at nearly $8k for the whole setup I certainly believe that they could've paid $5000 for the tower alone even though neither my system or theirs may not look like it to some.
At any rate we should just be happy and enjoy the time and effort that @jakeslayer9091 put into building this system even if they post the price in the title. Besides "5000$ Custom Loop water cooled PC" catches more attention than "I built a watercooled pc".
Cosmos Sv2:
  • OS: Win 10 Pro
Old School AMD:
  • GPU: XFX HD 7950
  • PSU: Corsair 650W
I think it's tacky. That's my opinion is all. Im not saying its not nice, but its like walking into a  bar and telling everyone how expensive your car is.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
I know what you are saying, but say someone like me who lives in Japan a Thermaltake Core P7 costs me $1,070 US dollars (I think it is about $300 US dollars on Amazon USA). Finding the absolute cheapest parts without considering how much it costs to get it to you (And that is the main reason it costs so much in Japan). My water cooling cost for my system, 4 x Radiators fans, pipiing, 3 x pumps, reservoirs and fittings are way over $3K US dollars. You know how much it costs to ship Ekwb products to Japan? Anyway, this is not a price contest and if it cost the OP that much, then thats fine IMO. That said, I am not disagreeing with you, but hope you have a more open mind that not everyone is able to source absolute cheapest price.
You're putting this in a rose colored glasses light, which is very 2020 and PC of you.
We all know why the OP put the price the very first thing in the title.  Please stop trying to twist is that @Statik is missing some vague point about location/region.  We all get that too.
If he had put the price as a total of all parts somewhere in the body, you'd have more of a leg to stand on.
As it is, price was the single most important thing the OP wanted to relay to us.  And very good for him, many can't afford that and he has a beautiful system to show for it.
Since you're not disagreeing with Statik, why must he be open minded more?  He's dead on, if you're agreeing.
OnePlus Ecosystem:
3D Printing:
Here's a link with the PCPartPicker list with prices from Canda,
Here are link for Water Cooling parts from Canada, They're not all the parts in the build, since I didn't add stuff like the fittings, tubing, etc., Also keep in mind these are without shipping since some of the stuff need to ship from other countries.
CPU Water Block [150$]: https://www.amazon.ca/EK-Velocity-D-RGB-Intel-Water/dp/B07L9YR1H3/ref=sr_1_1?keywords=EK-Velocity+RGB+(Nickel%2BPlexi)&qid=1578276479&sr=8-
GPU Water Block [250$]: https://www.amazon.ca/EKWB-Blocks-EK-Vector-Waterblock-Nickel/dp/B07NWP188X/ref=sr_1_fkmr0_1?keywords=EK-Vector+RTX+2080ti+w%2F+Nickel+Backplate+(Nickel%2BPlexi)&qid=1578276571&sr=8-1-fkmr0
Reservoir [750$]: https://www.amazon.ca/Bitspower-Touchaqua-Pump-Reservoir-Combo/dp/B07Q4R37PH/ref=sr_1_1?keywords=Bitspower+Touchaqua+rESERVOIR&qid=1578276836&sr=8-1
Radiator [280$]: https://www.amazon.ca/gp/product/B07W94H4G6/ref=ox_sc_act_title_4?smid=A1KNIZL1JRPIAI&psc=1
Total: 1530$ + 4300 = 5830CAD$
So 5830 CAD$ convert to about 4500 USD$, plus all the extra stuff that I didn't count and also the shipping and handling which would then prob sum it up to somewhere under 5000$USD
Obscene? The parts are marginally more expensive. A 9900K at Microcenter including tax converted to AUD is like $730.
