On the fly: My first build
JellOwned
Hey guys!
Around the end of april '12, I jumped on the 3770k and the Sabertooth Z77. I literally fell in love with both of them. The rest? It doesn't matter. So I picked anything. A couple of day ago I began looking at Linus's video and I realise that my rig is ridiculous/pathetic. I planned to upgrade/change some (lol) parts. I know that my cable management is terribad, and those fans... huhhhhhhhhhhh. If you guys got some tips or ideas it would be amazing :D
In a mind of vengeance, I'll show it to you!
Rig's Components:
i7 3770k @ 3.5Ghz
Sabertooth z77
Corsair Vengeance 2x4Gb @ 1600Mhz CL9
Radeon Sapphire HD 6970 2Gb GDDR5
Corsair Force GT SSD 120Gb
Corsair Force 3 SSD 120Gb
Seagate Barracuda 3Tb @ 7200Rpm 64Mb Cache
OCz Z-Series 1000w 80+ gold Semi-Modular
Cooler Master HAF-X
Cooler Master Hyper 212 Plus
Peripherals:
Corsair K60
Razer DeathAdder
2x ASUS PA238Q
Logitech Z523
SteelSeries Syberia V2 (Blue)
Microsoft LifeCam HD
Sabertooth z77 + CM Hyper 212 Plus mounted on the 3770k
Empty Cooler Master HAF-X
All the stuff installed
The back... :/
SSDs + HDD
Side view
Front view
Annnd... my setup!
Thanks! :D
It really isn't that bad! I just hate CM cases  :P.  If you want to make cable management better, route all the front panel connectors, USB, and HD audio under the motherboard.  My only question is why in the world a 1000W PSU?
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
Just change the GPU to something nicer like a GTX 770/GTX 780 and it's all good. I like it! It's nice.
And can I get a link to that wallpaper?
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
I start to hate it too... Especially the fans! 2x 200mm, a 140mm, a 230mm... For the PSU, I bought it for 79$ on DirectCanada... I was like Shieeeeeeeeeeeeeeeeeeet! Ahahaha. That's totally overkill and unnecessary.
Yeah... I took the same as my friend and It was an error ahaha. It's getting old! 2010 is far :)
Here's the wallpaper
Very Nice setup man doesn't look like it needs much at all really maybe try water cooling the Cpu with a H100i or equivalent and if you are interested also try a sound card as a suggestion.
I was talking with my friend about the H100i, H105, H110 or a Switftech H320. Sounds great to me, I want to replace that Hyper 212 Plus.
I thought those were dinosaurs.. Turns out it was just deer. Now I'm sad. :(
Awwww man! I'm so sorry :(
You had hope and I fail you...
Sabertooth board is best board
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
I love it! Thermal Armor  :wub:
It looks pretty decent, very simple, not overbuilt, clean. I like it! :)
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
Wow thank you mate! :)
Looks very clean! Much better than my cable management :P That Thermal Armour though. - Damn. Looks so good.
CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3
GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+
Thanks!
