Fan started smoking.
Hi there,
I accidently attached one of my fans to a JRGB2 output on the motherboard instead of a FAN output. It literally started smoking afterwards (from the fan motor thing). I turned computer off right away. Should I fear using this fan again?
Why would the JRGB2 output make the fan start smoking anyways?
Kind regards.
https://linustechtips.com/topic/1134452-fan-started-smoking/
you could try to, just dont expect best performance from it
shorting? If it's pushing 12V to the ground pin and ground to the 12V pin for example.
Desktop benching:
https://linustechtips.com/topic/1134452-fan-started-smoking/#findComment-13129020
Yup, dead.
RGB is 12V like fans, but since the plug is different you probably ended up connecting it with reversed polarity.
F@H
GPD Win 2
https://linustechtips.com/topic/1134452-fan-started-smoking/#findComment-13129021
Just to be on the save side I would replace that fan rather sooner than later.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1134452-fan-started-smoking/#findComment-13129702
12 hours ago, Juular said:
Different voltage.
Actually no, it's the missing ground pin. Both fan header and RGB push 12V max. But for RGB, pinout is 12V, G, B, R. For fan they are 12V, GND, RPM, PWM.
I would avoid using both. There are high possibility that header was also damaged.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1134452-fan-started-smoking/#findComment-13130523
  • 9 months later...
hey i had this same exact problem yesterday... i bought a replacement fan but also have some rgb lights that plugin into that exact rgb header. would it be safe to plug my rgb lights into that header despite the smoke? or should i not risk it. also, can i plug my new fan into the same header or should i plug it into a different one. thank you :)
https://linustechtips.com/topic/1134452-fan-started-smoking/#findComment-14083015
One, please don't necrp/hijack old threads. Two, the header might be fine. If there's no physical damage.
https://linustechtips.com/topic/1134452-fan-started-smoking/#findComment-14083284
