good case fans recommendation
bluehillday
looking for 3 good 120mm non rgb airflow fans (using a mesh front panel case)
the more silent they are the better
Arctic F12's. Can get them in all kinds of configurations for really cheap all around the world as far as I am aware.
My Rig:
Xeon E5 1680 V2 @ 4.5GHz - Asus Rampage IV Extreme X79 Mobo - 64GB DDR3 1600MHz - 8 x 8GB Corsair Vengeance Low Profile - CAS 10-10-10-27 - AMD Radeon RX 6700XT Sapphire Pulse 12GB - DeepCool E-Shield E-ATX Tempered Glass Case - 1 x 1TB Crucial P1 NVMe SSD - BeQuiet Straight Power 11 850W Gold+ Quad rail - Fractal Design Celsius S36 & 6 x 120mm silent fans - Lenovo KBBH21 - Corsair Glaive RGB Pro - Windows 10 Pro 64-Bit
Monitors - 3 x Acer Nitro 23.8" 1080p 75Hz IPS 1ms Freesync Panels = AMD Eyefinity @ 75Hz
You're using a dust filter in front of the mesh, right?
Noctua!
https://noctua.at/en/products/fan/nf-a12x25-pwm
Don't like the brown color?
https://noctua.at/en/nf-f12-pwm-chromax-black-swap
Don't like the price?
https://noctua.at/en/nf-p12-redux-1700-pwm
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
Noctua!
there isn't any dust filtter in front where is the mesh, there is in one on the roof and one under the psu
Then you can go with the airflow version of these. But if you have a dust-filter for the front, I would recommend using it instead.
FS in Denmark/EU:
System specs?
Where are you shopping / located? Budget?
On 12/14/2019 at 3:00 AM, bluehillday said:
i buy from here https://www.forit.ro/ventilatoare-radiatoare/
you can make a suggestions if you want
System specs?
12 hours ago, WoodenMarker said:
System specs?
asus z370 pii
i5 9600k
rx 570
corsair rm650x
16gb ddr4
cooler master mb511
i've purchased 3 arctic f12 120mm but they are loud at even 900 rpm. i will return them and get something else. maybe pure wings 2 120mm are more silent
If you're aiming for low noise, 900rpm is still fairly high. Have you tried lower rpm?
That being said, Arctic F12's are okay and not very quiet. Slipstreams are better: https://www.forit.ro/ventilatoare-radiatoare/scythe/108727-slip-stream-120-mm-800-rpm/
If you have more to spend, I recommend NF-P14S for front intake and a NF-S12A for rear exhaust:
https://www.forit.ro/ventilatoare-radiatoare/noctua/108744-nf-p14s-redux-1200-pwm/
https://www.forit.ro/ventilatoare-radiatoare/noctua/108922-nf-s12a-flx/
thanks. i've already tried some lower priced fans and they are really loud when they reach 800-900 rpm,had some silentiumpc sigma pro 120mm which are decent and pretty silent until 900rpm but they don't blow enough air, came to the conclusion that i rather play a premium price for something silent that blows air as well and not just tickles the dust of the components.
anyways i've already ordered 1x silent wings 3 120mm for exhaust since the stock 120mm cooler master fan that came with the case make a strange virbrating noise once it reaches 700-800 rpm
those noctua fans look good but aren't the p14s series designed for static pressure? will i not benefit more from the noctua s12b series which are for airflow since i have a case with a mesh in front?
I have found that fans below ~1000-1200rpm can't create the pressure needed to move air through a computer. Those airflow numbers for low rpm fans tends to be free air flow as in suspended with nothing in front or back other then the device checking flow speed.
That said, I find Noctua fans to be the best all round. They are low noise, quieter then the db ratings would make you think when compaired to others and yet they move a good amount of air, and they LAST.
The NF-P14S have good static pressure but are also fairly balanced. NF-S12B's don't have great static pressure and I'd hesitate to recommend them for a filtered intake. NF-S12A's are better overall if you really want to get 120mm's but the effectiveness of the lowest fan blowing into the psu shroud is questionable. That being said, it doesn't get much quieter than NF-S12A's if you don't mind sacrificing a bit of performance for very low noise.
Yeah,the 3rd fan points at the psu shroud. Unfortunatelly the case is designed in such a way that even if i place 2x140mm, half of the bottom,second fan will point at the shroud.
