I got a new 860 evo and it worked for a day then I switched motherboards and it stopped working. It would show up in bios for the first couple boots but wouldn’t show up in windows but not it’s completely stopped showing up in bios. I have a ASUS z390e gaming motherboard with a m.2 ssd and hdd that are currently working but the new 3rd isn’t. I’ve updating bios to the newest and have enabled csm. Please help and thank you.
change the port for the SSD.
My first though is your m.2 SSD is sata and the port your 860 is pluged into is wired to that m.2 slot.
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
does it have an information on it?
1 minute ago, CMBall said:
They’re all functional unless you turn up bandwidth for the 3rd pcie so I guess that can’t be the issue
Does the 860 evo have any data on it?
it worked before I switched the motherboard and slowly seemed to not work. It would show up in the bios once and I’d reboot and it wouldnt but now it won’t at all. I didn’t change the way I plugged it in between builds.
