What cable?
HD 6950 is WAAAAAAY to old to run 144hz.
You need to buy a GPU that supports HDMI 2.0 at a minimum. From memory your GPU only supports HDMI 1.4.
Main Rig:-
Server:-
1 minute ago, P_Zsolt_Daniel said:
hdmi(monitor can do 2.0 but I dont know about gpu)
Yup thats your problem, not enough bandwidth on HDMI to suply 144fps. But acording to the specs it should be able to do 120fps @ 1080p. so try that.
Else you need to get a Displayport cable. Just be carefull to chekc your GPU first as it can have miniDP connections.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
Thanks for the answer(it cant do 120hz on my pc but it can on my intel atom 2in1) I ll get a Displayport cable
3 hours ago, P_Zsolt_Daniel said:
Or should I try displayport
This.  It seems @HanZie82 has you covered though
GL :)
  • 2 weeks later...
21 hours ago, P_Zsolt_Daniel said:
Thanks everyone who helped I brought a Displayport cable about 2 days lafter the forum post and it works flawlessly.
My pc is still crap.
Thank for reporting back.
And your PC isnt that crap, it works. ;)
A non functioning PC now thats crap.
