What 140mm fan moves the most air?
19 minutes ago, Asaltnad0 said:I'm looking at getting some new fans I dont care about rgb and noise as long as it doesnt sound industrial.
Just looking for the most cfm ofcourse noctua comes first to mind but which one would you recommend? Or any other brand I dont quite understand the differences in them other than the bearing style, 3 pin or 4 pin, pwm. But could someone explain how you should choose a fan. I have a meshify s2 case.
From Noctua, the NF-A14.
They come in both normal and industrial versions.
Normals do 140 m³/h at 1500 rpm (25 dba , quiet), industrials can go up to 269 m³/h at 3000 rpm (41 dba, loud).
be quiet Pure Wing 2 140mm, are another option they are 1600 rpm and iirc have slightly higher airflow than the Noctua but lower pressure, and ofc are noisier than the 'normal 1500 rpm' Noctua NF -A14
