What the hell is happening. I recently bought a Ryzen 5 3600 to replace my 8 year old i5-650. In both systems i used a low end card, the amd r7 240 2GB. I thought i was going to get better performance when i bought the cpu, but today, i downloaded rainbow six siege and found that at the same configuration is running with less fps. The thing is absurd i had at the minumum configuration like 70 fps now i get less than 60 and when i look other players i get like 45... Is the temperature? the chipset is runing at 63° and the cpu gets up to 73°... but still, what is happening.
https://linustechtips.com/topic/1129621-is-my-ryzen-5-3600-worst-than-my-i5-950/
1 minute ago, nnnnnnnadie said:
8GB 2666 Mhz kingston one stick. In the other one i had 8GB in 4 sticks of 2 GB each at 1333 Mhz
So you have one stick of memory? I am not sure if that is the case but dual channel memory is generally preferred afaik. Also the r7 240 is not good for today's games.
whats ur motherboard, zen 2 needs 2 sticks at 3200, on top of that i'm guessing the vrm is having trouble with the boost clocks.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
You definitely need to be running dual channel memory, preferably 3200 MHz or higher. Furthermore your graphics card is completely unsuitable for today's demanding games, it's going to need to be replaced if you seek to gain any benefit at all from the platform upgrade. If running 1080P an AMD RX 5700 or RTX 2060 Super would be good places to start.
Main PC :
CPU = R9 3900X / Motherboard = Asus Crosshair 8 Hero / GPU = EVGA SC Ultra RTX 2060 / RAM = G.Skill 3600 16-19-19-39 ( 32GB / 4x8 ) / Cooling = Dark Rock Pro 4 / Storage = Western Digital Caviar Blue ( X4 ) Crucial 500GB NVME, 500GB 970 EVO/ PSU = Seasonic X-850 Modular / Case = Corsair Carbide 200R
Wireless = Asus PCE-AC56 / Keyboard & Mouse = Corsair K70 MX Blue, Logitech G203 / Headphones = Hyperx Cloud Alpha /
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
Did you reinstall windows? you went from a install on first gen core i series to ryzen 5 3600 there could be malfunction involved but other than that you also have to upgrade your video card, both are important.
Personal Desktop":
Luna, the temporary Desktop:
State clearly, which has 1 stick and which has 4 sticks. The 1st gen i7/i5 Core has triple memory layout IIRC.....so, I dunno what to make of your answer. For Ryzen, do get at least 2x 8GB DDR4 3200 Cl16 at the very least......DDR4 3600 Cl16 would be better.
Agreed, the R7 240 is just not enough. Whatever possessed OP to upgrade your CPU/Mobo/RAM and stick with the R7 240? That card is a serious bottleneck, little wonder you don't see a difference. I would suggest a mid tier card, like the VEGA56 Plutosaurus had recommended, but if that's too much, an RX580 (cheapest is about 160USD) which comes with one free game and should enable you to game at 1080P at High setting at the very least. Another thing to take care of is, update your BIOS, read up on how to do this (should be easy enough with an X570 mobo) with your mobo as the latest BIOS (AGESA 1.0.0.4) helps with boost clocks, stability and temps (IIRC).
Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Lexar NM790 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 23H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS)2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 23H2
The Game may have seen different hardware and redid autoconfig of settings as they sometimes do.
Make sure 100% the detail levels are the exact same and if you didn't know them before it could very well have changed anyway on its own now seeing different config on startup.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
