Need help deciding whether to get a GTX 1070 vs RX580
So I have two friends who are selling their video cards. One of them has a GTX 1070 (Zotac) and the other a RX580 8GB (Sapphire Pulse).
I know these two video cards have their pros and cons, but I'm undecided. I just mostly game on 1080p on an old 24 inch Dell 60hz monitor. I plan to buy a 27 inch 1440p monitor soon (around spring 2020). I do mostly gaming and do a little video rendering on Sony Vegas from time to time.
I currently have a GTX 1060 6GB (Palit Super Jetstream).
What do you guys think? Thanks in advance!
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
1070 all the way.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
1 minute ago, amdorintel said:
I am going to say
RX580
just cuz
if its cheaper, then why not?
Why not get something faster if you can afford it? Especially since OP will be getting a 1440p monitor and the 1070 will be better suited to that.
You already have a 1060
The 580 would be no upgrade, they're so similar in performance it would be redundant
Then the 1070 is also fairly close. It would be an upgrade, but not much of one.
Just save your money
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
The 1070 is about 50% more performance give or take than the 580 or 1060. At least from the benchmarks I've seen
How much your friends charge for 580 and 1070?
150 USD for the 580.
190 USD for the 1070.
I might be able to haggle the price a bit lower since these are two of my close friends. Lol.
私はオタクではありません。
Definitely 1070 for 1440P.
Neither, ~25% performance increase for the cost is way too little, unless you can sell the 1060 and get the 1070 within less than $50 from the sell price it isn't really worth the trouble.
The 580 is just a sidegrade so that's also not worth.
150 for a 580 is overpriced. They are readily available on Ebay for 120 shipped or less. A brand new one is 170 with a free game.
The 1070 is about market average
Yeah, that's what I was thinking. I'm leaning more towards the 1070 now. I still might be able to get it at a lower price if I try to haggle with my friend.
私はオタクではありません。
1 minute ago, manchild said:
1070 is not enough for 1440p anymore, need 1080 at least.
Really depends on the games and settings.. (seems obvious but many people don't think about only Ultra and AAA releases)
Many HUNDREDS AND HUNDREDS of games run very well on 2560x1440p on a GTX1070.
You can't make this statement a global one...
What I'd say is that you ARE seeing games at JUST 1080p Max settings go sub80fps on a GTX1070 in AAA games,..
So 1440p in AAA games you are mostly always going to lower settings going forward chasing 60fps at 1440p.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
well thats true. im the type who never plays below max setting (excluding AA which i hate). quite a few 2019 titles are lagging for me, and looking at benchmark 1080 is the way to go.
