Why is Power-line worse than wireless for me
I moved upstairs in an apartment and had no other network solution for my desktop, I had a random wireless repeater with an Ethernet port that I wasn't using anywhere else anyways. It was working okayish but kinda slow. Then in a recent WAN show, if I remember correctly, someone in my situation asked what wireless card to to get and Linus basically said don't get any wireless, just get cheap powerline ethernet adapters. So I got some, plugged them in...and everything was worse. I can tell in games and browsing the internet. I did a speedtest to be sure and I temporarily ran a long Ethernet cable up the stairs to verify.
Powerline:
Wireless:
Ethernet control test:
My Rig: CPU: 3570k@4.4Ghz | GPU: XFX r9 270x | Mobo: Asrock Z77 Extreme 4 | RAM: 16GB DDR3 2133 | Cooler: Hyper 212+
PSU: OCZ 700w | Sound Card: Creative Sound Blaster Z | Headphones: AD700 | Case: NZXT M59 | Monitor: 144hz 1080p
7 minutes ago, TheYonderGod said:
The copper in the walls probably just isn't up to the task, could always try a more mid ranged PoE option, but just running a cable through the apartment is likely much preferred.
What powerline adaptors did you use? Many don't have gigabit, only ethernet.
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Make sure the extension cords or whatever you have don't have various protections built in - those can filter or affect the signals the powerline adapters put on the AC wires. Ideally, plug the powerline adapters directly in the wall socket.
Also, the performance of these adapters will be much better if they're on same circuit. It's possible the sockets of the room below are on a separate circuit (with their own fuse) and your room above is on another circuit.
As an experiment, you could try to make the connection between two rooms on the same floor, or two sockets in the same room below and see if the speed increases.
And yeah, like the guy above me says, some of the cheaper powerline adapters advertise 300-600 mbps but have ethernet ports that can do maximum 100 mbps. The idea is that 300-600 mbps is the maximum amount of data that can move between let's say 5 adapters in the same house, moving through the network. Doesn't necessarily mean you get that maximum transfer speed between two adapters.
You should get 80 mbps or more, if the AC wiring is decent in your house.
if wireless works for ya, go for it. Powerline isn't the end of all problems, they have their own.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
2 x 15 meters cat6 cable and some switch between for increase signal should be enough. It's much better solution than powerline or wifi. Don't know why people are so afraid to use long cables - it may looks like not very pretty solution, but if you spend some time (mount cables to the wall, hide behind something etc) effect will be much better than using all that "magic" solution that makes your home prettier but less functional. :)
Ethernet works up to 100 meters without any losses or degradation of performance.
You don't need a switch between 2 15 meters of cable.
If you can have a cable through the house, then just buy a 30m or 50m spool of cable and use it, it will work fine.
I assumed he needs powerline or wireless due to difficulties with routing the cable through the house.
In what way is PoE used for internet access?
Both are plugged directly into wall. If they have to be on the same fuse that pretty much defeats the purpose, but I'm pretty sure I read that shouldn't make a difference. I guess Ill try it out anyways before I try to return these.
80-100 mbps would be okay... I'm getting 30/8.
Oh I forgot to mention the wireless is really old. 2.4ghz N300 (D-Link DAP-1330) and it's the default Comcast modem/router
The powerline is a TP-Link TL-PA4010KIT AV600
Trying to play games again, and they're lagging.
Yeah if it was my own house I'd just run cables in the walls. But I have roommates so it's not entirely my decision to have ugly cables through the house. Do you have any suggestions for no holes and no messy adhesive for mounting the cable ?
100Mbps aka ethernet - That is why you can't even reach +100Mbps
But my problem is it cant even reach ancient wireless speeds
Bad power cabling?
It's either the adapter that you bought, or more likely the copper inside the walls just kind of sucks for it.
Could also always try the Wifi 6 route, but that's a whole other issue.
That's theory, in practice 20 meters may be the limit for some cables (I had once that crappy cable marked as 5e, but speed lost was high over 15-20 meters), so I just wrote that just in case that if someone needs really long cables, may put switch in the middle.
In fact I have - do not mount them at all or use some existing elements (pipes, other cables) and zip ties. If cables are "ugly" for you and aesthetic is more important to you than functionality - be happy with very clean, cable free house and bad transfers. :)
Everyone has different point of view - for me my flat is not a museum, just place where I live and work. I prefer more cables and better speed than nice looking bottom part of the wall. If I wanted nice view, I can go for a walk to the sea - it's 10 minutes far from home. :P
Newer Powerline adapters use all 3 wires for data transfers from what I read. If your wiring is not new and or not to code, this will cause issues for you. Also the more breakers you have to cross the most interfrence you will have. If you have to cross a phase that will cause even more interfrence.
Powerline networking can be an issue in structures where the wiring pre-dates the mid 1970s.  It requires relatively modern and CORRECT wiring to run well, or at all.
Here is the preferential order of connectivity for a network, starting with best to least best:
1.  Wired (Ethernet).
2.  Wired (MoCA).
3.  WiFi
4.  Powerline
Note that items #3 and #4 will switch spots depending on your situation.
In gaming or 4K/HDR streaming scenarios, you REALLY wanted wired and preferably Ethernet.
< content removed >
Edited by LogicalDrm
