So I see 5700s on Amazon for 329 right now but they are the blower cards my question... Are the blowers REALLY that bad that id be worried about putting one in an ITX build I already have anyway or not?
I have an ITX 9400F intel system that I might want to move my RTX 2060 out of and put that card in my Ryzen 7 2700 box and I am considering putting one of these blower cards in that ITX build just cuz and I really don't do anything too intense with that system or anything would that be a good pairing or should I just drop the 5700 in my Ryzen??  Or just not buy a blower card because it will overheat and lock up my system all the time???
https://linustechtips.com/topic/1111535-navi-blower-card/
If the blower works anything like the old 7970's or 290X cards you'll probably be able to dry your hair after a shower with it if you turn it up. It'll be about as loud as a hairdryer too.
The blower style coolers aren't the greatest but they get the job done if keeping the card from overheating is the only goal. Just don't expect absolute silence to come with it.
https://linustechtips.com/topic/1111535-navi-blower-card/#findComment-12949215
All the reviews of the Navi cards that I saw, say the blower cards suck rather than blow... By this I mean, heat is terrible, and they are even louder. Check out Gamers Nexus on the Youtubes. Pretty sure hes done a breakdown of the good and the bad on the 5700 and 5700XT cards. Think the Sapphire pulse is one of his faves
My First (Current) Build:
Ryzen 7 2700 (3.90 1.35v OC) | Asus Prime X470 Pro | G.Skill Ripjaws V 16gb 3200 | Inland Professional 512gb M.2 NVME | Samsung 860 Evo Sata M.2 1TB | Corsair H115i Platinum | Corsair ML 140 RGB Fans | Fractal Design Meshify C | EVGA RTX 2070 XC Ultra
Laptop:
HP Spectre X360 13t Gem Cut (i7 8565u, 240gb, 8gb mem)
My Ride:
2015 VW Golf TDI Sportwagen
Eventually an XJ manual...
https://linustechtips.com/topic/1111535-navi-blower-card/#findComment-12949285
I'd only get a blower style card if you were going to liquid cool it. The Navi cards have had some terrible reviews regarding their blower style coolers.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1111535-navi-blower-card/#findComment-12949345
AMDs blower style cards are absolute trash. Avoid them.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1111535-navi-blower-card/#findComment-12951873
If you replace the thermal pads that AMD uses, with decent thermal paste, the temps drop considerably, and the blower fan will run MUCH quieter. It will still be slightly louder than a non-blower, but it will easily work quite well, and in general the blowers are better overall for ITX if you don't mind a little bit more noise.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1111535-navi-blower-card/#findComment-12953969
